Author Topic: Mounting a Happs 27" monitor bezel  (Read 2519 times)
ZaneMn
  • Last login:March 04, 2019, 11:11:15 pm
« on: February 28, 2003, 02:49:12 pm »
I just got my 27" monitor bezel for Happs and now I need to know how to mount this thing.  Do most people just screw the corners in to blocks of wood attached to the sides of the cabinet?  I want a nice looking solution hopefully one where the screws or fasteners do not show.
Thanks....
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:Mounting a Happs 27" monitor bezel
« Reply #1 on: February 28, 2003, 02:51:03 pm »
I've never done this since I am a n00b just starting to plan a cabinet, but can't you velcro it for easy removal to get to monitor controls?
Jungle
  • Last login:March 05, 2006, 08:38:19 pm
« Reply #2 on: February 28, 2003, 04:26:11 pm »
On my cabinet, which is 27" wide, I cut the bezel and Plexi to be 27 5/8" wide.  I then cut a 3/8" deep slot in each side panel on my cabinet using a router and straight edge.  The bezel and plexi are inserted into the slots.  My slot is a little wider than the thickness of the bezel/plexi combo, so I have some 2x2 scrap screwed to the sides (behind the bezel) to hold the bezel/plexi tight to the front of the slot.
No fasteners visible!
