Author Topic: Looking for Missile Command CPO Vector..  (Read 4236 times)
Moby Ick
  • Last login:February 12, 2007, 12:41:24 pm
« on: April 24, 2006, 09:09:29 pm »
Can anyone send me a vector of the Missile Command CPO?  The one at the Arcade Art Library seems to be corrupted (unlike all the others, I can't open it up in photoshop on my Mac)
Thanks Much
Luigi
  • Collecting/restoring cabs
Re: Looking for Missile Command CPO Vector..
« Reply #1 on: April 25, 2006, 03:16:34 am »
Hi Moby :)
I made the Missile Command CPO with CorelDraw and converted it to ai for uploading to Localarcade.
Since no one told me it doesn't work, I thought it was ok....it seems not :(
Have you tried to OPEN or to IMPORT the ai-file? When I try to OPEN with Corel  it says that it is the wrong format but I can IMPORT it into an existing drawing....weird ;)
What formats can you open in your Photoshop? Does it support CorelDraw (.cdr) ?
If yes, I can email it directly to you.
Bye
Thorsten
zorg
« Reply #2 on: April 25, 2006, 03:52:01 am »
the missile command cpo is correct, it opens fine
I'm on the planning stage
Moby Ick
« Reply #3 on: April 26, 2006, 12:46:50 pm »
I'm opening it in photoshop (I dont have illustrator or correldraw). I have no problem opening any other vectors from the site. I get an error of "Could not complete your request because the parser module cannot parse the file"
I get the same error in two different copies of Photoshop.  I'm using CS2 Photoshop on the mac so maybe its a mac thing. I've never had problem opening an .ai file before.
Wierd.  I guess I'll try opening it from a PC at work and converting it to a tiff or something.
Luigi
« Reply #4 on: April 27, 2006, 02:43:05 am »
Hi moby.
I can make a bitmap of it. Just tell me what size and format it shall be. I will upload it to my personal webspace and you can download it from there :)
zorg
« Reply #5 on: April 27, 2006, 03:26:44 am »
I'll will made an eps for you and up-it somewhere.
Moby Ick
« Reply #6 on: April 27, 2006, 07:01:02 am »
Thanks Zorg, sorry for the trouble.
Mike
zorg
« Reply #7 on: April 28, 2006, 04:04:29 am »
here it is
http://edeveaud.free.fr/tmp/Missile_Command_CPO.eps
I've checked that it opens fine in photoshop 7.0
Moby Ick
« Reply #8 on: April 28, 2006, 07:27:12 am »
Thanks.  It worked perfectly.
mike
Luigi
« Reply #9 on: April 29, 2006, 04:13:26 am »
Yesterday evening we attached the printed CPO to the panel....it fitted perfectly :)
