Author Topic: Using a metal hole saw on aluminum  (Read 2714 times)
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« on: April 20, 2006, 02:48:04 am »
I want to use a 1 3/16" metal hole saw to cut my holes in my cp that has the artwork attached.  I have an industrial size drill press at my disposal, so with that said, do you guys see any issue with using this method?  I will be installing translucent leaf switches, thus the slightly larger hole size.  Will jumping around occur?  I don't see how it would be that great, but thought I would ask first.  The overlay isn't cheap. :dizzy:
TOK
  • The Game Always Wins
Re: Using a metal hole saw on aluminum
« Reply #1 on: April 20, 2006, 06:06:04 am »
I think the heat would be a bigger problem for the overlay. I think I would use a metal punch to do this... Not sure if thats the correct name. They're the things where you drill a small pilot hole and attach the two cutting sides with a bolt. When the bolt is tightened it cuts the metal.
We use them to cut the external sheet metal on our work vans to route wires. Makes very clean holes and doesn't burn the paint.
« Reply #2 on: April 20, 2006, 07:11:30 am »
I second the hole punch, they work great.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #3 on: April 20, 2006, 10:14:08 am »
Good point.  The biggest problem I have seen with those is finding the right size.  I'll put some effort into it today.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: April 20, 2006, 11:16:15 am »
Yes, a Greenlee brand "knockout punch" (a.k.a. "chassis" punch) would be a choice in your application. If you were to use a hole saw on aluminum, the aluminum would quickly clog the hole saw teeth. You should use cutting oil on aluminum anyway, but the cutting oil would get underneath the overlay of yours and ruin the adheisive.
Go to Home Depot in the electrical section and buy a Greenlee knockout punch for 3/4" electrical conduit. It will punch the correct hole for game buttons.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #5 on: April 20, 2006, 12:22:30 pm »
I thought I needed a little bigger hole for leaf switches?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #6 on: April 20, 2006, 12:46:35 pm »
I have just seen through using the search tab(amazing huh?), that the only reason 1 3/16th holes are needed is due to the little triangle tabs on the bottom side of leaf switch buttons.  I also read that one of the members used a hobby knife to cut those out, so I'm going to give it a shot.  I also attempted to fit one of the leaf switches into a hole on my old microswitch control panel and it went in snuggly.  I plan to make a full tutorial on this once I have the products in hand.
BTW, does anyone know what size greenlee punch is needed for the trackball?(I measured 3 1/8th myself).  I don't know what size greenlee punch that would be.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: April 20, 2006, 04:42:32 pm »
Which TB do you have?  Almost all 3" TBs need a 3" hole.  AFAIK, only Happ's HighBall model is different, and needs a 2.25" hole.
Happs links: normal TB dimensions and HighBall dimensions
Robin
Knowledge is Power
telengard
  • Last login:April 01, 2026, 04:20:10 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #8 on: April 20, 2006, 09:50:00 pm »
Hi there,
My control panel modules are aluminum and I haven't had any issues w/ it although I do not have artwork on the modules (yet).  It actually cuts pretty clean and easily and I'm using a handheld drill w/ hold saw.  It is MUCH better than what I had previously which was plate steel.  Yikes   :dizzy:
I'm surprised that it's aluminum and not steel.  My original control panel was steel.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #9 on: April 20, 2006, 10:04:37 pm »
I just made a little tutorial on how I made my holes.  They were a hair too small for the leaf switches.
quarterback
« Reply #10 on: April 20, 2006, 11:00:59 pm »
Exactly!  In your previous search you must not have found my "Battle Royale Thread" where the masses kept trying to convince me that my leafs were going to fit into 1-1/8" holes even though it was clear they were not.
For those who are interested, you can start with this post and read the back and forth..  I finally had to contact Knievel via a PM and beg him to post in my thread since people didn't seem to believe me that it takes a 1-3/16" hole for leaf buttons to be installed in a metal CP, not 1-1/8"
-- Chad Tower
