Author Topic: Monitor Jitters  (Read 1655 times)
clite_rad
  • Last login:June 09, 2006, 10:52:57 am
Monitor Jitters
« on: April 19, 2006, 07:51:47 pm »
I just acquired a new cocktail game with a 14" monitor. The game plays great but the monitor jitters in the horizontal when the game first starts and it somewhat clears up when the game is on for a long time. I know that it will probably need a cap kit. What I'm wondering is if there are other things I can check to make sure it is not something else before I do a cap kit to it. Is there some simple things that I can check that may be causing the jitter.
Ken Layton
  • Guru
  • Technician
Re: Monitor Jitters
« Reply #1 on: April 19, 2006, 11:30:43 pm »
Bad solder joints and a capkit.
lettuce
  • Make It So!
Re: Monitor Jitters
« Reply #2 on: April 22, 2006, 06:35:51 am »
My WG K7000 does the same, its ok after 5 minutes of being on though, if you give the cab a shake then it snaps out of it, doesnt flicker all the time when its cold though, only now and then. Would you say the same thing is needed Ken? I have no idea what is involved in a Cap Kit by the way, and my soldering skills are only basic!
SirPeale
  • Green Mountain Man
Re: Monitor Jitters
« Reply #3 on: April 22, 2006, 09:56:10 am »
lettuce: definitely sounds like bad solder joints.  I'd go there first.
Practice soldering on something you don't care about first.
Ken Layton
  • Guru
  • Technician
Re: Monitor Jitters
« Reply #4 on: April 22, 2006, 10:39:30 am »
The k7000 is well known for solder problems. I suggest also purchasing a good magnifying glass and sitting down with the chassis under a good fluorescent light source.
