Author Topic: monitor problems  (Read 1911 times)
deadhead
  • Last login:March 29, 2003, 02:00:06 am
monitor problems
« on: February 27, 2003, 10:10:26 pm »
Hi all, I still have some issues with my cabinet that I can
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:monitor problems
« Reply #1 on: February 28, 2003, 05:03:58 pm »
Did you set either mame or ArcadeOS to use an arcade monitor? If you did, change it back to normal PC monitor, as that will mess up the display.
When you exit ArcadeOS, how does DOS look?
deadhead
Re:monitor problems
« Reply #2 on: February 28, 2003, 07:39:18 pm »
I used fraggle
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
Re:monitor problems
« Reply #3 on: March 01, 2003, 12:59:29 am »
I've been doing some reading because I want to do exactly what you are doing as well...
From what I can tell, Fraggles boot cd uses advance Mame, and on the Ultimarc site, they specifically mention that the ArcadeVGA card elimates the need for Advance Mame and that if used together, Advance Mame will overwrite the settings that the card automatically takes care of.  Try loading up DOS and using dmame with ArcadeOS instead.  I'd also suggest going through the forum on ultimarcs site and the ArcadeOS forum as well, they are both linked at the top of the page here.
