Author Topic: Need a demo copy of adobe illustrator 6.0  (Read 1886 times)
Mr_Biggs
  • Newbie
  • Last login:July 12, 2006, 08:20:41 pm
« on: April 15, 2006, 08:04:20 pm »
hi all, i have macromedia flash 5, and for some reason the artwork i do in it will not print properly. so i exported it in adobe illustrator 6.0 format. i know it will work in newer versions, but im cursed with dialup, so d/ling a 400MB file isnt gonna work. im hoping AI 6.0 will be smaller, but i cant find it. does anyone have it or a link?
The below statement is false
The above statement is true
dirkamiss
  • Last login:August 03, 2006, 06:49:18 pm
Re: Need a demo copy of adobe illustrator 6.0
« Reply #1 on: April 15, 2006, 08:18:38 pm »
Well after a quick search I couldn't find a download for 6.0
But really I think you should still get CS2 its much more improved.  Plus I don't think that the filesize would be extremely different.  And if you have Illustrator you won't need to create your artwork in flash anymore.
Another option would be to go to a local library or school and download it there, then transfer it with a flash drive. And if you don't have a flash drive you should definitely consider investing in one.
Good Luck.
Mr_Biggs
  • Newbie
« Reply #2 on: April 15, 2006, 08:40:25 pm »
Good Luck.
That's not an option, i'm homeschooled and all the libraries here want mad cash for internet use. i'll probably have to bug a friend to get it.
dirkamiss
« Reply #3 on: April 15, 2006, 10:01:51 pm »
Whoa!   Libraries are charging for internet use?  That doesn't make sense.  I wonder if they charge you to rent books too.  Around here, you just need a library card.
I'd offer to download it for you, but I don't really think that would help your cause.
ChriX
  • Last login:March 23, 2013, 05:02:04 am
« Reply #4 on: April 17, 2006, 07:03:32 am »
What is so impossible about downloading 400MB on dialup? It would only take just over a day. I used to get 1.5GB down in a week on dialup with plenty of time to spare! If you started it when you made this post it would be done by now. :)
