Author Topic: Thick-gap T-moulding ?  (Read 1894 times)
exiges
  • Last login:November 24, 2006, 02:57:03 pm
« on: April 13, 2006, 08:53:06 pm »
While renovating a cab I bought from Ebay, I've discovered that it's not using standard gap T-moulding.  The strip is still 3/4" wide, but the gap seems twice as wide as standard.
Does anyone know a company that supplies alternative T-moulding ?  I couldn't find anything other than 3/32" gap on T-mould.com
AtomSmasher
    • Atomic-Train
Re: Thick-gap T-moulding ?
« Reply #1 on: April 13, 2006, 09:00:19 pm »
If you can't find any wide-gap t-molding then you can always just fill the gap with wood putty then re-route it.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #2 on: April 14, 2006, 06:13:57 am »
Either that, or use hot melt glue to fasten your T-Molding into the existing gap.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
« Reply #3 on: April 14, 2006, 10:25:36 am »
Or put some duct tape on standard t-molding to widen the insert strip
wrench
  • Last login:August 02, 2024, 03:16:38 pm
  • Another project I couldn't say no to
« Reply #4 on: April 15, 2006, 12:03:47 am »
http://www.t-moulding.com does sell some moulding with a slightly wider spine 7/64 instead of 3/32 but not in 3/4 inch,you would need to use a wider moulding and use an edge trimmer to flush cut it to the cabinet.But if your slot is as wide as you stated it may not be enough for you.The normal slot width for moulding with a 3/32 spine should be 1/16th.
exiges
« Reply #5 on: April 16, 2006, 11:45:20 am »
Update:  I contacted T-molding.com who were helpful.. but require an order of 10,000 ft  :laugh2:
Instead, I filled the gap with super adhesive Sikaflex, waited til it was really tacky (only a few moments) and then stuck it down with that.  Sikaflex being handy in that it's black (my cab + T-moulding is black)
Only downside is that there's no way that's coming out now ! LOL
