Author Topic: I-Pac wont scroll HELP PLEASE  (Read 1338 times)
rollerball
  • Last login:March 16, 2010, 07:56:57 pm
« on: April 13, 2006, 03:10:22 am »
Hey there everyone....maybe one of you out there Might know whats wrong with my I-Pac....I got it off ebay second hand...all seems to be working fine but when I try and scroll up or down the game list it is with one game at a time ....Ive tested the repeat key with the keyboard and it works fine...when I try it with the I-pac it dosent work...gone into control panel and keyboard and tested the repeat keys in there...same thing...keyboard works I-Pac dosent...Im using windows 98...and emu loader as a front end....even switched and used mame32 and still same thing....if anyone has the same prob or has any idea would be great to hear your ideas...thanks....paul
rollerball
Re: I-Pac wont scroll HELP PLEASE
« Reply #1 on: April 13, 2006, 03:12:11 am »
Oh yeah its going in ps2...its not a usb I-Pac...
rollerball
« Reply #2 on: April 13, 2006, 03:30:08 am »
Just read that If I get a ps2 to usb adapter and plug my ipac into usb then it turns the key repeat back on for scrolling...is this correct???
Havok
  • Trade Count: (+17)
« Reply #3 on: April 13, 2006, 09:44:15 am »
Check out this page:
http://ultimarc.com/ipac2.html#troubleshooting
If that doesn't help, try contacting Andy for support:
http://ultimarc.com/contact.html
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: April 13, 2006, 12:24:07 pm »
Hmmmn - it should work - from my page:
OTOH, the I-PAC supports key repeat on the 1 Up and 1 Down inputs only in PS/2 Mode.  In USB mode, key repeat is supported on all inputs.   Andy Warne can supply an I-PAC supporting key repeat on all keys in PS/2 mode, if requested.
So as long as your joystick is wired to 1Up and 1 Down, those should scroll.
You aren't using any of the HotRod or X-Arcade controller options with EmuLoader are you?  (but then it wouldn't scroll with a keyboard).
