Author Topic: Monitor hook-up  (Read 1820 times)
zudmsc
  • Last login:September 07, 2011, 07:44:26 am
Monitor hook-up
« on: April 06, 2006, 05:56:27 pm »
Do I need to discharge a monitor to connect it to or disconnect it from the power source??
Zud
grantspain
  • Last login:Today at 06:40:05 am
Re: Monitor hook-up
« Reply #1 on: April 07, 2006, 02:36:04 pm »
what do you want to do?,the only time you need to discharge a tube is when you are changing a chassis or need to remove it for service reasons i.e changing componants
zudmsc
Re: Monitor hook-up
« Reply #2 on: April 07, 2006, 03:09:56 pm »
Thats what I wanted to make sure.  I wanted to get an arcade monitor to test two PCBs that I have.  I have been reading as much as I can on the fourms about it.  I wanted to make sure I could just buy a moniotr and hook it up to the power supply and be done.
Zud
