Author Topic: Laminate how much and where to buy?  (Read 1663 times)
jefurse
  • Last login:March 20, 2008, 11:08:42 am
« on: April 06, 2006, 10:19:17 am »
Just starting to build a cab, where is the best palce to buy laminate and how much should it run per square foot? Thanks. Should I try Home Depot or specialized shops?
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re: Laminate how much and where to buy?
« Reply #1 on: April 06, 2006, 10:49:08 am »
I've had great luck with www.cabinetparts.com.
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
« Reply #2 on: April 06, 2006, 10:49:49 am »
I did a search and found this...hope it helps.  Only used paint myself in the past, but I'm looking to laminate my next one, just haven't gotten that far yet.
http://forum.arcadecontrols.com/index.php?topic=48853.0
Please post your results, and pics.
Good luck!
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
jefurse
Thanks, great suggestions
« Reply #3 on: April 06, 2006, 11:41:42 am »
I like that vinyl suggestion, looks to be a cheaper alternative. I will eventually print some artwork for the side and control panel, so I won't need alot. Thanks, again.
clhug
  • Last login:April 04, 2024, 10:49:58 pm
« Reply #4 on: April 17, 2006, 08:32:09 pm »
Oh, I've been wondering about this and I saw this thread so I thought I'd ask here.
I found this vinyl stuff that looks like it'd be easy to use.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-018
The problem is it only comes in 2 ft wide rolls.  Does anybody know of any other places that may sell this stuff in 3 ft wide rolls?  I've searched high and low and can't find anything like this anywhere else.
Zeitgeist
  • Last login:June 05, 2013, 05:57:51 pm
« Reply #5 on: April 17, 2006, 10:31:13 pm »
I have looked around for quite a while for this in a wider that 2 foot sheet but have had no luck at all.
I have however seen different types of vinyl in a three foot roll for auction on ebay that do look promissing if you do not want to have a seam at the 2 foot mark.
« Last Edit: April 17, 2006, 10:32:58 pm by Zeitgeist »
There is a theory which states that if ever anyone discovers what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.
