Author Topic: cocktail control panel depth??  (Read 1494 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: March 30, 2006, 03:16:05 pm »
OK, I am now ready to start building my control panels for my cocktail table.  I am building them out of 3/4 inch mdf and my questions is how deep/tall should they be?  I need to be able to mount a 3 inch trackball from GGG, twister from GGG, 360 joysticks and electric ice buttons from GGG.  How many inches do I need to mount these, 4"??
I b**ch. People listen!!
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
Re: cocktail control panel depth??
« Reply #1 on: March 30, 2006, 04:08:34 pm »
I believe that commercial tables are 4" thick.
Although, If you CP is 3/4 then that leaves you with 3 3/4 without a bottom piece.
I suppose that one could make it any size as long as all your sticks fit inside. I made some out of cardboard first and smaller that 4" looks weak. I tried 7 1/2 because I had left over oak play-wood left over that was this size. But If you go too fat one wont have room for knees and coin door. Plus it looks top heavy. I finally went back to 4" but I have metal CPs that give me more room than you will have.
The deepest joystick I could find was the Happ's top fire and I think it hangs down about 3.5 inches due to the extra switch on the bottom.
As for track balls, I got a Happs GT and it sits about 3" below the CP. But a bestson I don't have a clue.
Good luck!
They treated me like an animal and that's what I became.
squirrellydw
« Reply #2 on: March 30, 2006, 04:20:48 pm »
so you think as long as the inside depth is 4 inches I should be ok?
