Author Topic: Monitor problems  (Read 3009 times)
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
Monitor problems
« on: March 29, 2006, 11:53:55 am »
 having  a Problem with my new monitor. The bottom left corner of the picture looks discolored almost like it is dirty.So I used a mointor test program and notice some things. The top left corner jets in like 5 degrees and I can't correct it with the osd. Also the corner that looked dirty can't saturate its colors. It looks like there is a magnet is being held by it. Other than that monitor looks good.
KDOG
Re: Monitor problems
« Reply #1 on: March 29, 2006, 12:00:08 pm »
more pics
grantspain
  • Last login:Today at 01:26:16 am
« Reply #2 on: March 29, 2006, 12:30:35 pm »
its a degauss issue,try rotating the monitor by 90 degrees see if it helps,otherwise you could have a fault on the degauss circiut or a magnetised frame/bolt
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: March 29, 2006, 04:54:52 pm »
What kind of monitor?
Usually these problems go away on their own after a while.
NO MORE!!
Ken Layton
  • Guru
  • Technician
« Reply #4 on: March 29, 2006, 06:14:18 pm »
Your monitor needs to be manually degaussed with a hand degausser coil.
KDOG
« Reply #5 on: March 30, 2006, 12:41:27 am »
Thanks for the info Ray, grantspain, and ken. This is my first arcade monitor so I didn't mess it up by doing some thing wrong. I did try the built in dedauss but it only helped a little. Where would you buy a degausser coil at ? I know there is a way to make your own some where in the fourm.
edit
Ray it is a billabs bl27cb1t goes up to 800x600
« Last Edit: March 30, 2006, 12:43:44 am by KDOG »
mj147
  • Last login:May 19, 2026, 07:47:25 pm
« Reply #6 on: March 31, 2006, 04:27:53 pm »
Heyas Kdog
I recently had your same problem but my monitor wasnt able to completly degausse itself.
I happen to remember a G4 program (Attack of the show) that showed you how to make your degausser (sp?)
http://www.g4tv.com/attackoftheshow/blog/AOTB/post/466253/Screw_This_Degaussing_Drill.html
http://66.102.7.104/search?q=cache:obDIrdibqkgJ:woil.ws/fixmonitor/+magnet+drill+degauss&hl=en&client=firefox-a
One is a vid and other is instructions
Hope this helps
Mj147
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #7 on: April 01, 2006, 05:01:19 pm »
I picked up a degausser on ebay for about $25 a few months ago, it was used but it got the job done.
My Websites
