Author Topic: need happ P360 measure.  (Read 3725 times)
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« on: March 25, 2006, 01:08:48 am »
right now my CP is cut out for ulrimarc t-mag and one of hole (center of hole) is just under 3 inches from one of holes for trackball mount.
see i might buy p360 sometime in the future when i have money
so that's why i need measure of p360 so if i want to change joystick in the future it will fit in tight space.
anybody?
My website: www.bossyman15.com Lots of arcade pictures inside!
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
Re: need happ P360 measure.
« Reply #1 on: March 25, 2006, 01:18:29 am »
I think all of the happs bases are the same. So if you can find  either a super or comp measurement you should be strait.
RichyRich
  • Last login:November 17, 2006, 12:22:40 am
  • If it ain't broke don't try and fix it
« Reply #2 on: March 25, 2006, 07:55:22 am »
It will not fit,but you could always drill the hole pattern in the base of the 360.
bossyman15
« Reply #3 on: March 25, 2006, 08:39:42 am »
well you could just give me the measure of the base and i will cut it out on paper and see if it will fit.
Quarters
  • Last login:July 08, 2010, 06:53:17 pm
  • I am not now, nor have I ever been, a llama!
    • Quarters Arcade Site
« Reply #4 on: March 25, 2006, 08:47:40 am »
The p360 base is a standard 3'' by 3.5'' same as most joysticks. There are some exceptions.
The pattern from the happ ultimate will work fine.LINK
« Last Edit: March 25, 2006, 09:13:16 am by Quarters »
97.4 percent of all statistics are full of crap.
bossyman15
« Reply #5 on: March 25, 2006, 10:09:42 am »
Exceptions? What exceptions?
And which side is 3" and 3.5"? Top/bottom or left/right side?
RichyRich
« Reply #6 on: March 25, 2006, 10:57:51 am »
I got both sticks and they do not match,can't be arsed to measure.
bossyman15
« Reply #7 on: March 25, 2006, 12:13:44 pm »
Everybody everybody everybody.... Anybody who have P360 would please help a fellow out and measure the top square base. Or any site with tempte of P360 would be helpful.
rwhip41
  • Last login:April 04, 2006, 12:46:36 am
« Reply #8 on: March 25, 2006, 01:00:46 pm »
The 360 I have measures 3.482" left to right and 2.985" up to down as it would sit in a control panel. In case it's relevant, it measures 0.305" thick.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #9 on: March 25, 2006, 01:01:32 pm »
This is the P360 mounting, actual size.... Print it at 72dpi... and yes it is the right way round.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
Flinkly
  • Last login:July 30, 2026, 06:03:12 pm
« Reply #10 on: March 25, 2006, 01:29:05 pm »
you could mount a 360 the wrong way and just change the contacts.  see, it has contacts labeled up down left and right, but if you oriented the joystick the skinny way, you could just change left and right to up and down and vice versa.
RichyRich
« Reply #11 on: March 25, 2006, 02:41:51 pm »
Hey fozzy, are you sure thats the right way round? if I pushed up on mine with your template it would activate right or left.Mines 90 degrees rotated???
EDIT:you could be right fozzy,I think I remember undoing the four screws and turning it now ,so its easily altered.
bossyman if you follow the link that Quarters kindly posted, the outside holes are the exact size of the 360.There are no inside holes on the 360 like other Happ bases which is why it wont fit your pattern but like I said earlier you could drill your own.
« Last Edit: March 25, 2006, 02:57:32 pm by RichyRich »
Fozzy The Bear
« Reply #12 on: March 25, 2006, 02:59:19 pm »
Interesting.... Mine in my first panel is that way round.... rwhip41 appears to have it that way round as well according to his measurements.
Best Regards,
RichyRich
« Reply #13 on: March 25, 2006, 03:15:19 pm »
Just checked and you can rotate it so you can have it either way but it is sent like your template.
bossyman15
« Reply #14 on: March 25, 2006, 05:17:59 pm »
Everybody thank you for your repies. Those info are very helpful. I will check it out when I get home from work within the hour.
bossyman15
« Reply #15 on: March 27, 2006, 03:37:28 pm »
Best Regards,
how do i print it at 72dpi?... what program do i use?
bossyman15
« Reply #16 on: March 27, 2006, 03:55:27 pm »
oh never mind i got it
i loaded it up in visio and got it.
it printed out as 3 9/16" x 3 1/8"
is that right?
rwhip41
« Reply #17 on: March 27, 2006, 11:28:19 pm »
I already supplied the measurements above from my 360. I used my micrometers, which are accurate to 0.001". Based on those measurements and those supplied by others, I would rely on 3.5" x 3".
Havok
  • Trade Count: (+17)
« Reply #18 on: March 28, 2006, 08:43:20 am »
Best Regards,
If you want the contacts to be correct (left is left, etc.) then you have to mount it "sideways" with the contacts to the right. You could mount it any way you want, just be aware you have to switch your connections to compensate...
RichyRich
« Reply #19 on: March 28, 2006, 09:15:41 am »
not true....if you undo the four screws on the base you can turn the sensors 90 degress to match up.It's really easy to do.
Havok
« Reply #20 on: March 28, 2006, 09:44:41 am »
It's true until you do that...
Fozzy The Bear
« Reply #21 on: March 28, 2006, 10:04:32 am »
When you print it just tell your printer to print at 72dpi.....  ::)  In you printers properties screen.
Either that or load it up in something like photoshop if you have it and resize it to 300dpi while keeping the actual dimensions.
Best Regards,
RichyRich
« Reply #22 on: March 28, 2006, 11:18:04 am »
lol
