Author Topic: Please send me a GBA PocketRom directory listing ....  (Read 2352 times)
unclet
« on: March 24, 2006, 06:21:15 pm »
I am hoping someone who has a complete set of Heaven Pocket Roms can send me their rom file directory listing.  I need a directory listing of all the Rom files which are prefixed by the related heaven pocket numbers used for the pocket Rom naming convention.
I went to the Heaven pocket rom site and their list does not help me since it does not list the "actual" names of the Rom filenames but rather only lists the name of the game.   I am looking for a list of the actual Rom file names please.
One way to do this is to open a command prompt window, go to the directory which has all the GBA pocket Romfiles and then simply capture the directory listing into a file by using the following command (ex: "dir > out.txt") ..... then send me the file.
I have all the GBA screenshots but their filenames do not match the same name as the associated Rom file.  The screenshot filenames I have only consist of the heaven pocket number only.   I would like a list of the actual Rom files which show the related numbering format so I can then rename all of my screenshots to share the name of the actual rom file......
Of course if someone would like to provide me with an already correctly named set of GBA screenshot files, then that would save me a lot of time.  If not, then a directory listing of the Rom files would suffice .... and I will start renaming the files manually.....
UncleT (emailAddrRemoved)
« Last Edit: February 22, 2008, 09:47:15 am by unclet »
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: Please send me a GBA PocketRom directory listing ....
« Reply #1 on: March 24, 2006, 09:49:46 pm »
Have you tried this?
http://www.gba-renamer.com/
It can put the numbers, country, correct name, etc.
I used it last night to sort the carts by country, then remove the numbers. (I use a supercard)
Later,
dabone
unclet
« Reply #2 on: March 24, 2006, 10:33:07 pm »
Thanks for the tip, however, I really do not have the patience to learn something new at this point.  It took me forever to obtain the full GBA Rom set and do not want to use an application in which I could mess something up.
I am really just looking for a GBA Rom directory listing in which I could simply cut-and-paste the filenames over .....   if you have one or know how to get one, that would be excellent help for me ...
dabone
  • Time to work...
« Reply #3 on: March 25, 2006, 08:41:51 am »
So you would rather spend a hour or  2 renaming file, or spend 5 mins downloading this, telling it where the roms are, and then telling it where to put the renamed roms?
This program is very simple to use and updates to rom file listing online.
Also, make a backup of the files before doing any file operations to them.
Later,
dabone
unclet
« Reply #4 on: March 25, 2006, 10:44:35 am »
You are correct .... so I downloaded the application, installed it, upgraded to the latest DAT file, set my "paths" to where my Rom files were as well as indicating where the renamed Rom files should be placed.   I clicked "GO" then got an application error congratulating me that I found a program error.
Basically, nothing happened.   Anyway, it was not a total lost ....I was able to list all the rom file names associated with the DAT file and cut-n-paste the list to my harddrive.  I am now cut-n-pasting manually .... oh well..... ::)
jcrouse
    • CPViewer
« Reply #5 on: March 25, 2006, 04:21:05 pm »
That must be why you make useless posts of things that have been ask MANY times before (use the search feature) AND do not take advice when offered.
 :banghead:
John
unclet
« Reply #6 on: March 25, 2006, 06:20:51 pm »
In all fairness, I was not asking for a tool to perform conversion, but rather just a directory listing file .... that was it....
I do not believe me searching the FAQ or in past posts would reveal that someone already posted an updated directory listing of the heaven pocket roms ....
As it turns out, I created a little VB program to convert all my files for me, based on the actual Rom file name I obtained using the GbaRom renamer application, so it actually did help me out .... and I did say thank you for that ... and meant it.
After I convert all the screenshots for the pocket Rom set, then I think I might try to get them posted on the "Screenshot" site.   I will try to get the screenshot set with and without numbers posted.   Might even include the "titles" as well ......  another little contribution from me regarding screenshots ..... if they are accepted on the site of course ....
« Last Edit: March 25, 2006, 06:24:10 pm by unclet »
dabone
  • Time to work...
« Reply #7 on: March 25, 2006, 11:24:49 pm »
Glad you got it going.
That's strange the the app didn't work with you, I used it on 3 different machines in the last week.
(Been working on converting the file names out so my kids can use the super cards easier.)
Later,
dabone
p.s. Screen shots would be great, I might even think about putting the gba games back on the main mame cab again.
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #8 on: March 29, 2006, 04:02:10 am »
I expect that my next emumovies release will be the GBA game prieviews.  Should be done in the next month or so.  Way better than game snaps  :applaud:
My Websites
