Author Topic: Table saw question  (Read 1508 times)
sodapopinski
  • Last login:February 12, 2011, 11:13:41 am
  • if I only had normal friends
Table saw question
« on: March 23, 2006, 09:21:46 am »
Even though i'm a carpeneter i have a quick question. How do you make a rip over 45 degrees when your table saw only tilts that far. a jig?
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Table saw question
« Reply #1 on: March 23, 2006, 09:40:01 am »
Yeah,.... I would.... Angle plate on the table surface should do the job, but it is pushing the limits a bit. Probably also needs two people on hand to do it if it's a large piece.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
Ayrk
  • Last login:January 09, 2023, 03:09:42 pm
  • I'm 99% complete, will I ever finish that 1%?
« Reply #2 on: March 23, 2006, 09:51:58 am »
Subtract the angle you want from 90 degrees, tilt the blade that much, and flip your board over so you are cutting the inverse. For example, if you need a 60 degree angle, set the blade at 30 degrees and flip the board around.
I'd recommend practicing on a scrap piece or two, I know it took me a few tries to get it right.
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #3 on: March 23, 2006, 02:05:56 pm »
Depending on the size of the wood.  You can turn the wood 90 degrees and run it through vertical.  If it's a giant piece it will probably be too hard to manage that way though.
Next I'll be on fries, and that's when the big money starts rolling in.
Nannuu
« Reply #4 on: March 23, 2006, 02:25:04 pm »
Like this.
Nannuu
« Reply #5 on: March 23, 2006, 02:41:54 pm »
Hmmm, now that I think about it, you asked about ripping.  I guess that would mean you are trying to cut a piece in two.  I would still have to say cut in two and then try to run vertical.
sodapopinski
« Reply #6 on: March 23, 2006, 07:39:16 pm »
thanks Nannuu,, your idea will work. I suppose I can angle it on end, then rip to size.
