Author Topic: Problem with KE72 PC Keyboard Encoder  (Read 1084 times)
jonnyv100
  • Last login:June 11, 2007, 08:33:14 am
« on: March 21, 2006, 09:19:26 pm »
I've run into a small problem and was wondering if anyone has a solution.  When I wire up a button to my KE72 I see the key being pressed in a word document everytime I press the button but when I map it to a the same key in a Mame game it only seems to work after 3 or 4 pushes.  Has anyone experienced this problem and have a solution?
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
Re: Problem with KE72 PC Keyboard Encoder
« Reply #1 on: March 21, 2006, 10:35:08 pm »
I have a KE72 installed in my first upright from several years ago.
I don't ever recall seeing the condition you are experiencing.
Do you have a keyboard installed to the pass through port?
I have a kb attached all the time inside the cab and still have no issues but I thought it might be something you might use to troubleshoot.
