Author Topic: High Voltage Probe Recommendations & Questions  (Read 5345 times)
lameboyadvance
  • Last login:April 29, 2006, 11:02:56 am
  • Kind of a Nintendo freak...
    • VeeBee Development
« on: March 18, 2006, 12:33:00 am »
I've had both my arcade cabinet & TV/monitor for a while now, and I figured it was time I started doing something.
I've been reading about the whole monitor discharge thing, and since I may have to remove the anode/chassis from the tube while inserting the TV screen I've decided to invest in a discharge tool, just in case.
I've read about the DIY 'short-n-sharp' methods, but I've also read that some monitors prefer a resistance be inserted, which is when I found out about HV probes.
  • Firstly, can these probes actually be used as resistance based discharge tools?
  • Secondly, what max voltage rating (30/40KV) would be best for not just arcade monitors, but any CRT?
  • And finally, does anyone have ones they would recommend? Remember that I'm a cheapass with no money so nothing too flashy. ;)
Thanks in advance.
grantspain
Re: High Voltage Probe Recommendations & Questions
« Reply #1 on: March 18, 2006, 01:14:54 pm »
well  buy two long plastic handled screwdrivers,thats really cheap.
lameboyadvance
« Reply #2 on: March 18, 2006, 08:10:29 pm »
I've already read about that, but as I said some CRTs don't like the immediate discharge of shorting the anode, plus I prefer something with a gauge rather than hearing for a (sometimes non-existent) crackle.
...And I don't trust my soldering skills, especially around HV equipment. ;)
« Last Edit: March 18, 2006, 08:13:02 pm by lameboyadvance »
cw
  • Last login:March 26, 2026, 09:24:03 pm
  • Game over man game over
    • The Cab
« Reply #3 on: March 20, 2006, 09:49:15 am »
Most of the stuff that I have read have pointed to older b&w moniotrs and  vector monitors thats have an inline hvdiode right off of the hv cage or flyback wichever the case my be.  It can blow this diode but not everytime... I have seem people argue this point and say not to worry about it.  I on the other hand go by the book... the atari big book...
lameboyadvance
« Reply #4 on: March 21, 2006, 04:45:45 am »
Or in my case, the Apple Tech Docs. :)
...So noone has/is using an HV probe? Surely everyone doesn't solder 2 screwdrivers together...
Ken Layton
  • Guru
  • Technician
« Reply #5 on: March 21, 2006, 10:40:26 am »
1. YES
2. Most go up to 40kvdc
3. Visit www.mcminone.com and check out their "order" numbers 73-520 and 72-6530. Both are excellent units. The "Tenma" brand is MCM's own brand and in this case their order number 72-6530 is an excellent clone of the B&K brand (# 73-520) at a fraction of the cost. If you want cheaper then go to ebay and look for used Heathkit and Pomona brand probes. Several years ago I got a great used Pomona one for $20 with safety orange colored padded carrying case to protect it. Remember that these probes (as are many pieces of test equipment) are very delicate and don't take physical abuse.
I am a professional and I always use a high voltage probe to discharge a tube. You can tell right away if the tube is discharged or not. HV probes are very useful in diagnosing startup/overvoltage problems in monitors/tv sets. If you do lots of monitor or tv work then this is an essential tool you can't live without.
