Author Topic: GameEx questions!  (Read 1732 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
GameEx questions!
« on: March 15, 2006, 02:10:14 am »
Hi all.
I've been reading about GameEx here at work, and have seen this screen:
http://www.tomspeirs.com/gameex/Images/10.jpg
Now, can you remove the 'Exit GameEx' option for dedicated arcade? I don't
my guests to be able to exit to windows :)
The green arrow and question mark in the top also looks too 'PC-like'
Can all these things be changed easily?
Nicholas
sWampy
  • Last login:February 02, 2010, 04:23:40 pm
Re: GameEx questions!
« Reply #1 on: March 15, 2006, 09:06:24 am »
The exit can be removed for sure with a dropdown box on the config.  I'm not so sure about the green bar, but I think so with a different theme.   You could/should post this in his forums, he is very good about answering questions.
Gameex isn't/wasn't really designed with standalone cabinets in mind.  Tom's goal started off to make it an extension of windows media center edition.   It has most of the abilities of other frontends, plus a ton of media center kind of functions, plays videos, displays rss feeds, streaming audio/video from the web, remote web interface to control/stream video/audio.   If you want something that completely doesn't look like windows, atomicfe or mamewah might be better choices.   Frankly I use all 3 and swap around all the time so my cabinet always seems fresh when friends come over.
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« Reply #2 on: March 15, 2006, 04:19:36 pm »
Yes...everything is in the config app, there is an "arcade mode" to remove the MCE toolbar at the top, as is an option to limit the shutdown proceudres.
