Author Topic: Mamewah Kenga Fusion question? Video issue (fps but no picture)  (Read 4482 times)
haldir
  • Last login:February 01, 2019, 09:16:07 am
I checked the forums and did not find an answer, So here goes the question.
I have kenga fusion up and running in mamewah where the game loads and exits just fine.
Now I don't get picture or sound, but the FPS is running the corner so I know it brought up fusion.
I am trying to figure out if it's the INI or a setting missing in fusion.
here's my ini:
### 08segag.ini (mamewah v1.61) ###
emulator_title                            SEGA GENESIS
### List Generation Settings ###
rom_path                                  c:\segag\roms
rom_extension                             gen
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\segag\fusion.exe
commandline_format                        c:\segag\fusion.exe "[rompath]\[name].[romext]" -gen -fullscreen{nodosbox}{nosafelaunch}{8.3[rompath]\[name].[romext]}{nodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]
alt_commandline_format_2                  [name]
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      c:\segag\screenshot
artwork_2_image_path                      c:\segag\controller
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
« Last Edit: March 13, 2006, 03:08:59 pm by haldir »
jcrouse
    • CPViewer
Re: Mamewah Kenga Fusion question? Video issue (fps but no picture)
« Reply #1 on: March 13, 2006, 03:22:59 pm »
Your emulator commandline needs to look like this:
c:\fusion\fusion.exe "[rompath]\[name].[romext]" -gen -fullscreen{nodosbox}{nosafelaunch}
Yours seems to be parts of two pieced together.
John
haldir
« Reply #2 on: March 13, 2006, 03:31:35 pm »
Thanks so much for the reply :)
However, it still did not fix the problem so it has to be a setting in fusion.
I'll start diggin..
No luck on settings inside fusion. The only thing I can think of is it may be a resolution issue?
« Last Edit: March 13, 2006, 04:04:16 pm by haldir »
« Reply #3 on: March 14, 2006, 04:51:07 am »
Does it work OK when opening a game within Fusion (ie not via Mamewah)?
You could try using {safelaunch}, *if* this only happens when launching from Mamewah...
haldir
« Reply #4 on: March 14, 2006, 02:45:18 pm »
Thanks for the reply minwah :)
Yea it works just fine if I run Fusion by itself. Only when it runs through mamewah.
« Reply #5 on: March 15, 2006, 05:18:52 am »
In that case:
haldir
« Reply #6 on: March 15, 2006, 12:02:15 pm »
 c:\fusion\fusion.exe "[rompath]\[name].[romext]" -gen -fullscreen{nodosbox}{safelaunch}
I ran it with safe launch and I'm still getting the issue. It runs just fine when I play fusion itself. Any other ideas?  :D (this is so stupid )
jcrouse
    • CPViewer
« Reply #7 on: March 15, 2006, 12:09:39 pm »
This needs to be some minor oversight. MANY people use Fusion with MameWAH and I have never seen an issue. Post your ini file again and also a clean Mamewah.log file.
John
haldir
« Reply #8 on: March 15, 2006, 12:21:46 pm »
LOG FILE
3/15/2006 12:18:14 PM MAMEWAH launched
3/15/2006 12:18:14 PM Cursor scheme: (None), Arrow: (None), Wait: (None), AppStarting: (None)
3/15/2006 12:18:14 PM Desktop colour: 6838104
3/15/2006 12:18:14 PM Wallpaper filename:
3/15/2006 12:18:14 PM Display mode: 1280x1024 @ 60Hz, 32 bit colour
3/15/2006 12:18:14 PM Decimal symbol: '.'
3/15/2006 12:18:14 PM Games list read: 08segag-0.lst
3/15/2006 12:18:16 PM Layout selected: C:\mamewah\layouts\Custom\08segag.lay
3/15/2006 12:18:17 PM Ctrlr file selected: C:\mamewah\ctrlr\default.ini
3/15/2006 12:18:18 PM Commandline run: c:\segag\fusion.exe c:\fusion\fusion.exe "c:\segag\roms\ZOMBIES ATE MY NEIGHBORS (U) [F1].gen" -gen -fullscreen {flags=17}
3/15/2006 12:18:32 PM MAMEWAH quit
INI:
emulator_title                            SEGA
rom_extension                             gen
dat_file
nms_file
catver_ini_file
commandline_format                        c:\fusion\fusion.exe "[rompath]\[name].[romext]" -gen -fullscreen{nodosbox}{safelaunch}
artwork_2_image_path                      c:\segag\controller360
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                launch_scr
movie_path                                c:\mamewah\ssmovie
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]
scr_file                                  c:\arcade\support\ms_pacman.scr
### External Application Settings ###
ipc_file_or_path
app_1_executable                          c:\cpvw\cpvw.exe
app_1_commandline_format                  -b=c:\cpvw\images\sega.jpg
app_2_executable                          c:\cpvw\cpvw.exe
app_2_commandline_format                  -b=c:\cpvw\images\mamewah.jpg
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path                                c:\Arcade\mp3
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
I have a feeling that it might be the "- gen" area of the INI. Reason being the software loads just fine in mamewah but the game won't load. Options while in fusion work as well (region, hard reset....etc) so I know that the software is not locked up.
jcrouse
    • CPViewer
« Reply #9 on: March 15, 2006, 01:04:08 pm »
OK. You are using 1.61. I think your problem is that you have duplicated the executable. You specify it as both the "emulator_executable" and again ont the "commandline_format" line. This is wrong. I forget what is right but know that is incorrect. Set yout "emulator_execitable to whatever the path to fusion.exe is. Something like so:
emulator_executable        c:\fusion\fusion.exe
and your "commandline_format to this:
I think that will do it.
Let us know,
John
jcrouse
    • CPViewer
« Reply #10 on: March 15, 2006, 01:09:00 pm »
Let us know,
John
So you know, in 1.61, it takes the "commandline_format" and appends it to the end of the "emulator_executable". This builds a string that is sent to mamewah. Yours currently looks like so:
c:\segag\fusion.exe c:\fusion\fusion.exe "[rompath]\[name].[romext]" -gen -fullscreen{nodosbox}{safelaunch}
That is why I replied as I did above. I could see the double executable. You need to remove the "c:\fusion\fusion.exe" (without the quotes) from the "commandline_format" entry just leaving the rest. I would also change {safelaunch} to {nosafelaunch} and try that.
John
haldir
« Reply #11 on: March 15, 2006, 01:49:28 pm »
That was it. Simple, stupid on my part, and like they say live and learn.
I can not thank you enough for taking the time to help. I truly appreciate it and all the work you put into this forum.
Thank you so much!   ;D
jcrouse
    • CPViewer
« Reply #12 on: March 15, 2006, 01:55:51 pm »
No problemo senior!
John
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
« Reply #13 on: March 15, 2006, 02:07:57 pm »
No problemo senior!
John
You've been spending way too much time in Mexico =P
Brad
