Author Topic: Coin op MAME?  (Read 12166 times)
marcoval
  • Last login:December 02, 2004, 02:40:59 pm
  • www.scottishninjas.com
Coin op MAME?
« on: February 21, 2003, 02:58:42 pm »
I am interested in making my MAME cab to be set up to take quarters/tokens, for the feel of an arcade game not profit. I'm sure there have been many who have done this, but I'm just not finding.  I have a coin mech from an old Pengo cabinet I have that I'm pretty sure is in working order, but I just need to know how to get it to send a signal to MAME that a token has been inserted.
Every millennium
A warrior emerges.
Trained in the deadly arts of the ninja.
Moving with the swiftness of the wind
Striking with deadly accuracy
They are proud
They are strong
They're Scottish
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
Re:Coin op MAME?
« Reply #1 on: February 21, 2003, 03:12:39 pm »
You've got a couple of options :).  Wire the coin door up to the "5" or "6" key on your keyboard, or buy an iPac or Keywiz and wire it into there.  It's actually very simple, and very cool.
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
_Iz-
  • Last login:Yesterday at 10:55:56 pm
  • Time to coin up!
Re:Coin op MAME?
« Reply #2 on: February 21, 2003, 03:12:53 pm »
Pressing "5" in mame adds coins. So wire the coin switch to something capable of sending a 5 to mame (like a keyboard hack, IPAC or Keywiz). You could also remap mame to coin-up on a joystick button press and then wire the coin switch to a hacked gamepad...
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
Re:Coin op MAME?
« Reply #3 on: February 21, 2003, 03:48:36 pm »
The switch is at the bottom of the coin mech (usually) and has a inch or two long wire sticking out of it.  throw a quarter through your coin mech and watch carefully, at some point the coin will move the wire thus tripping the switch.
All the coin switches I've seen have nice terminals, just like button switches, so you can wire them just like you wired all the rest of your buttons.
Except for the fact that a coin closes the switch instead of your finger, it's really the same as a button.
JustMichael
  • Mmmmm!! Cheesecake!!
Re:Coin op MAME?
« Reply #4 on: February 21, 2003, 04:19:00 pm »
All the coin switches I have seen have .250 male terminals while the buttons normally have .187 male terminals.  Keep this in mind when ordering female quick disconnects.
JayTea
  • Last login:July 10, 2009, 03:32:25 pm
  • Whatchu talkin 'bout, Willis?
    • Licoricepizza.com
Re:Coin op MAME?
« Reply #5 on: February 22, 2003, 02:58:22 am »
187? 250? Quick Disconnects?
     I just refurbished an old Stern Berzerk Coin Door with one switch (the other is missing).  I have not tested to see if the one I have actually works, but please tell me the differences between the 187 and 250 switches, and why do I need to buy a quick disconnect (what is a quick disconnect?)  Obviously it disconnects something qucikly, but what?  I will be hooking the door up to an IPAC.
By the way, anyone know the voltage on the bulbs in the Stern Coin Doors (circa 1980)?  Thanks for everyone's help in advance.
ps, i have thought of changing my name to "rookie".... ???
JT the Footballguy
Step in the Arena
killr0y
  • Last login:November 03, 2003, 03:41:29 am
  • The Dude abides
Re:Coin op MAME?
« Reply #6 on: February 22, 2003, 05:05:13 am »
Quick disconnects are the connectors you crimp on your wires that slide onto those flat connectors on your button switches, controllers, etc.
187's are .187 inches, or 3/16".  the 250's are 1/4"  -- This refers to the width of the terminal blade that the quick disconnect will fit.
Picture of quick disconnects (with plastic shielding)
« Last Edit: February 22, 2003, 05:11:18 am by killr0y »
MinerAl
  • duck
Re:Coin op MAME?
« Reply #7 on: February 22, 2003, 10:33:04 am »
I've only played with two vintage coin doors, one Atari and one Data East, but both of them used automotive 12-14V lamps.  If you have the old burned out bulb, take it to the automotive aisle at your local whatever-mart and find the closest match.
If you're MAME-ing the machine, just make sure you use (the computer's, or a wall-wart transformer's) 12V supply for the lighting and you'll be fine.  If you're restoring a cabinet with the original power supply you may want to break out a voltmeter to see what the bulb's socket is running at.  If it's 14V or less you're good to go.  I'll bet it's 12V, but better safe than sorry.
_Iz-
  • Time to coin up!
Re:Coin op MAME?
« Reply #8 on: February 22, 2003, 11:30:22 am »
Mine had 6v bulbs. The person I bought it from told me that was the norm. No idea what the cab/coin door was originally. I wired both 6v bulbs in series to 12v on my PC powersupply.
JayTea
    • Licoricepizza.com
Re:Coin op MAME?
« Reply #9 on: February 22, 2003, 12:09:51 pm »
Thanks for the details on the .187 and .250 ... sometimes the answer is right in front of you and you still can't see it (well, at least I didn't).  The quick disconnect thing didn't register, becasue everything on my door is soldered so i didn't think...plus if you look at the time I posted it was about midnight - I really need to get out more :)
Thanks again!
JT
JT the Footballguy
Step in the Arena
marcoval
Re:Coin op MAME?
« Reply #10 on: February 22, 2003, 02:27:47 pm »
Wow, I love this board, plenty o answers! Thanks to all! I know where the trigger wire is, how do I convert it to use .900 tokens instead of quarters?
Every millennium
A warrior emerges.
They are proud
They are strong
They're Scottish
StephenH
Re:Coin op MAME?
« Reply #11 on: February 22, 2003, 03:40:41 pm »
Actually, it is quite easy.    If you wire up your coin door coin switches to an encoder, and then in MAME, actually map those inputs to the keys for "Insert Coin" (defaults to 5 and 6).
marcoval
Re:Coin op MAME?
« Reply #12 on: February 28, 2003, 01:29:07 pm »
So, anyone know how to modify it to take tokens instead of quarters?
Every millennium
A warrior emerges.
They are proud
They are strong
They're Scottish
_Iz-
  • Time to coin up!
Re:Coin op MAME?
« Reply #13 on: February 28, 2003, 01:45:46 pm »
A quick google turned up this...
http://www.flipperit.net/tkalliok/flipperi/rahalukko_en.html
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:Coin op MAME?
« Reply #14 on: February 28, 2003, 03:15:16 pm »
Not sure if the modern plastic mechs have that adjustment but you can easily buy coin mechs for tokens as well.
If you build a frankenpanel, chances are I don't care for you as a person.
