Author Topic: Brightness changes height and contrast causes H-Hold to get screwed on U2000  (Read 1436 times)
DirkDiggler_ESQ
  • Last login:June 01, 2011, 10:26:09 pm
The latest in my saga with my U2000 is this:
This monitor has a remote control board with brightness, contrast, h-hold, v-hold, etc on it.
If I adjust the brightness Pot, the brightness changes, but the height of the image also changes as well.
If I adjust the contrast, the contrast changes, but if I change it too much, the horizontal hold gets totally screwed.
Any idea what is happening?  Should I replace R101 on the deflection board?
grantspain
sounds like maybe a dry joint on the remote board or its connection onto the chassis,or even poss a pot breaking down
Ken Layton
  • Guru
  • Technician
Has this monitor had a capkit installed? If not then install one.
