Author Topic: Okay, new one for you boys and girls involving plasma cutting  (Read 1819 times)
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
I have found a metal shop that will cut out my four person cp with a plasma cutter buttons and all for $50.  It is 16 gauge metal.  I need to provide a .dfx file for the cutter.  If I have my layout made in Adobe Illustrator, is there anyway to convert over the measurements into such a program?  If anyone could help I would greatly appreciate it.  I think that is a pretty solid deal for metal and all, so I'm pretty stoked.  I will be posting my layout later tonight.  Thanks in advance for any help.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Okay, new one for you boys and girls involving plasma cutting
« Reply #1 on: March 07, 2006, 06:28:13 pm »
I think you mean .dxf file... That's a txt based CAD description file generated by AutoCAD and also generated by CAD programs that can produce AutoCAD compatible files.
The only way I know of to convert an illustrator file to that format is to copy it into the CAD software as a graphic and trace the image. But in order to do it accurately you really need to re-draw it properly in CAD software. Which does mean understanding and learning to use a CAD program.
Otherwise you'll have to pay them (probably a large sum) for their time to draw it for you.
The other option is to ask on here... Somebody may have the time to help you out, by re-drawing your panel as a .dxf....  I would offer to help you with this one, but I'm snowed under with work right now.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
« Reply #2 on: March 07, 2006, 06:48:53 pm »
I can convert it for you.
Give me a PM.
BTW plasma is not exactly the most accurate way to cut metal but it should do for a CP, just don't get too tight on your tolerances.
NoOne=NBA=
« Reply #3 on: March 07, 2006, 06:54:07 pm »
Illustrator will export .dxf files.
Whether they will be workable at the other end is a bit of a crapshoot however.
They work fine for some of my vendors, but not for others.
I've got several suppliers who prefer .eps files, and use some kind of a conversion program at their end to create the .dxf files themselves.
PoDunkMoFo
    • Visual Horizons
« Reply #4 on: March 07, 2006, 07:12:39 pm »
This is the way I would do it.  I have seen strange stuff happen when trying to import native illustrator files into other programs.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #5 on: March 07, 2006, 08:58:03 pm »
Thanks for the replys fellas!  I wouldn't have a problem if the buttons were off a little, but.............. I am using the Illustrator file as the base for the artwork, so the major concern is that my $100 investment in artwork doesn't go to waste or vise versa.  So, with the accuracy issue brought to light, is this method reliable?  Are we talking about being a hair off or a button off? ;)  If any of you guys that have the experience with this stuff could give me your honest opinion, I would appreciate it.  My other option that I considered was to get the artwork done, get the metal, apply the artwork, and use a greenlee punch to make my holes exactly and cut straight through the artwork and the metal.  Does that seem feasible?  WWSD?  What would Saint do? ;D
PoDunkMoFo
    • Visual Horizons
« Reply #6 on: March 07, 2006, 09:14:31 pm »
Not that inaccurate.
A plasma cutter heats the metal up to molten hot then blasts the molten metal away w/ air (basically).  Not as precise as say a laser of a waterjet.  Just give yourself a little and don't make the holes the exact size you need them.  Make them a little bigger just like if you were cutting them out of wood.  Plasma cutting is more of an issue in thicker materials because you kind of get a tappered cut but in your case I would not worry.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #7 on: March 07, 2006, 10:18:35 pm »
Excellent news!  Okay, I will post the .ai file later here and in my announcements thread.  Thank you so much.  This is really exciting news, as I have never worked with metal.  The metal place is also going to do my side art in diamond plated metal.  Who knew a place like that was ten minutes from my house?! 8)
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #8 on: March 08, 2006, 12:27:06 am »
Did you guys know you both have the same job?
PoDunkMoFo
    • Visual Horizons
« Reply #9 on: March 08, 2006, 12:34:25 am »
You mean NBA is a contract killer too.  8)
Wow man small world.
« Last Edit: March 08, 2006, 10:06:19 am by PoDunkMoFo »
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #10 on: March 08, 2006, 06:09:56 am »
Okay, I have posted the layout over in my project announcements thread.  I am waiting to hear some feedback, then I will make it final.  I will certainly keep you updated!!!
