Author Topic: How Do You Create A Listxml In Mame?  (Read 24922 times)
M.A.M.E Power
  • Last login:February 06, 2007, 04:25:59 pm
  • There Are So Many Games!
« on: March 03, 2006, 03:16:07 am »
Ok, i know this must be straight forward!
I am running the latest version of mame and open the command prompt and type the following to create the listxml.
d:\mame\mamepp.exe -listxml
Now it goes through all the roms, but does not produce an output - am I missing something from the end of the command line?
Have tried searching but cannot seem to find the answer ???
The reason I want to create the list is to try jcrouse cpviewer.
cdbrown
  • Bowowow
Re: How Do You Create A Listxml In Mame?
« Reply #1 on: March 03, 2006, 06:07:45 am »
mamepp.exe -listxml >listxml.txt
you need to tell it where to put the listxml info
M.A.M.E Power
« Reply #2 on: March 03, 2006, 09:52:14 am »
Thanks for the heads up.
Ok I have now encounted another problem ::)
Following the instructions in the cpviewer docs - I open up the command prompt and get to the mame directory and then type the following:
D:\mame> mame -listxml|xml2info > "d:\cpvw\CPViewer\MameGames.cfg"
It then says that mame is not an operable programme, I realise why it is saying that, but what excatly do i need to type in order to create the cfg file?
Lea
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #3 on: March 03, 2006, 10:07:34 am »
Code: [Select]
mamepp -listxml|xml2info > "d:\cpvw\CPViewer\MameGames.cfg"
M.A.M.E Power
« Reply #4 on: March 03, 2006, 11:04:46 am »
Well that was obvious >:(
Ok am now as far as I have got a cpviewer template completed and saved ready for use. I have also got the history dat file as well as histview.
I have copied and altered what is on jcrouses site:
general_app_commandlines                  d:\cpvw\cpvw.exe -r=[name] -c=[cloneof];d:\cpvw\controlsviewer.exe mamewah;d:\histview\histview.exe -r=[name]
For some reason this is not working - I check the mamewah error log, but it seems the software is not being loaded once I have selected a game?
Any pointers?
Cheers
Lea
