Author Topic: Who would like a KeyWiz MAX option that offered Hi-Bright NL and CL LED Support?  (Read 2381 times)
RandyT
  • Last login:May 04, 2026, 05:18:46 pm
    • GroovyGameGear.com
Here's the deal, folks.  The KeyWiz MAX has been ready to support this feature for a while now and it's been beta tested for about a year on one individual's panel.
I've also just provided it to another by request.
So here's the question:
Would you like to be able to connect Ultra-Bright LEDs (with resistor) for NL and CL LED functions, that do not blink when buttons are pressed and do not remove the use of any of the 32 inputs (when used with 2 joysticks) , for an extra $5 on the top of the normal MAX price?
If so, I will make the option available on the site.  If not, I won't bother with another version for now.
Thanks,
RandyT
« Last Edit: February 28, 2006, 12:58:47 pm by RandyT »
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
NL and CL LEDs?  ??? Will they still be animate-able and select which ones are lit by a command-line program?
RandyT
No, the LED-Wiz is still the way to go for fancy stuff.
This is just an advanced way of dealing with the NL and CL LEDs that uses some extra hardware and some tricks to accomplish.   So if you like the blinky light that some games give you when you add a credit, then this will let you add a high intensity LED (~20ma)  to whatever 2 buttons or indicators you want to reflect those functions.  It only supports the primarily used CL and NL leds, not the SL (Scroll Lock.)
RandyT
Tiger-Heli
    • Tiger-Heli
NL and CL LED's = NumLock (Player 1 in some MAME games) and CapsLock (Player 2 in some MAME games) LED's.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Would you (or do you already) also offer the LED?  and if so could I choose color?
Hoopz
  • Last login:April 26, 2026, 09:04:18 pm
  • Intellivision Rocks!
Thanks!  ;D
 I couldnt figure those out.  Not being an LED expert, I thought the terms referenced LED info.
Patent Doc
  • Last login:March 25, 2021, 12:07:33 pm
  • My wife says I'm the fastest man alive :(
Randy
Check your PM
Patent Doc
psychopanda
  • Last login:August 31, 2006, 01:13:17 pm
    • PsychoPanda's Secret Grotto
Hmm, that's interesting. Two questions pop to mind:
1) Can the light signals be reversed? ex. Player 1 lights up UNTIL you deposit a quarter. (the 'feed me' response)
2) How many games actually support this function? If there is enough supported games, I would be interested.
Tiger-Heli
    • Tiger-Heli
Anything CAN be done if you understand the MAME source code and want to modify it.  Otherwise, I don't think so . . .
Mostly Atari Stuff - BattleZone, Asteroids, AstDelux, pac man in some versions of MAME. . .
