Author Topic: Power Switch on Arcade  (Read 7222 times)
zudmsc
  • Last login:September 07, 2011, 07:44:26 am
« on: February 27, 2006, 03:34:27 pm »
Ok, I have an old Galaga upright game.  It has a new power supply on it and the interlock switch has been moved, not removed.  The power swith on the top of the cabinet is gone.  I would like to add it back again.  Do I need just a simple SPST toggle switch?  How would I hook the lines to the switch?  Should I use an extension from the interlock switch or straight from the power supply??
Michael
« Last Edit: March 02, 2006, 08:37:47 am by zudmsc »
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
Re: Power Sitch on Arcade
« Reply #1 on: March 01, 2006, 09:02:56 pm »
I would imagine a SPST would be waht you need.
Is this an AC to DC power supply, or AC to AC which has multiple feeders?  Either way, do you want the switch to break the line to the power supply completely, or have the power supply always hot and only break all or some of the feeders?
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: March 02, 2006, 12:41:14 am »
I think the proper thing he's looking for is installing a switch on the main AC into the cab.
NO MORE!!
Rocky
« Reply #3 on: March 02, 2006, 07:02:47 am »
You can get by with a SPST switch. Wire it to cut the power on the live side of the AC input before it goes to anything else. You can leave the interlock or remove it.
I prefer a DPDT switch.  I've notice on some games where the on/off switch only switches one side of the ac that there is some voltage leakage. I can meter 6-8 volts with the switch off.  It's probably my house wiring.
Good luck,
Rocky
zudmsc
Re: Power Switch on Arcade
« Reply #4 on: March 02, 2006, 08:43:39 am »
Right now I have to just unplug the game to turn it off.  I am trying to restore it as close to the original as possible.  Someone installed a new power supply before I bout it.  It is new, not old style and yes I beleive it converts to DC.  I want to keep the interlock switch and relocated it so when you take the back off the game, power is cut off.  I believe I want the switch on the top of the cab to kill all power to the cabinet.  Is that correct?  I dont want voltage leakage.
Michael
JeepMonkey
« Reply #5 on: March 02, 2006, 09:41:07 am »
If both switched will kill the incoming power, then you could use two normally closed switched wires in series.  Opening either switch would break the circuit.
fredster
  • It's all good!
« Reply #6 on: March 02, 2006, 10:47:43 am »
Does the machine still have the wire running up to it?
If it does, it probably just has the wire spliced together. Put your switch in just one side of that and you will be okay.
There is a diagram for this on Bob Robert's site.
zudmsc
« Reply #7 on: March 02, 2006, 11:03:08 am »
No, the wires up to the switch are missing.  I would have to double check though.  Do you have a link for the diagram on Bob Roberts?  I cannot remember the website address.
Michael
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
« Reply #8 on: March 02, 2006, 07:26:47 pm »
here's the link to Bob Roberts site
http://homearcade.org/BBBB/siteindex.html
There are three kinds of people in the world those that can count and those that can't.
RayB
  • There's my post
    • RayB.com
« Reply #9 on: March 03, 2006, 01:23:46 pm »
NO MORE!!
