Author Topic: problem with Fraggal boot cd  (Read 2056 times)
POS
  • Last login:March 22, 2006, 01:31:02 pm
« on: February 27, 2006, 12:50:16 pm »
It seems to load fine but will not boot after restart.  It goes to an X: prompt and when I cd to c: and EXE arcadeos it wants to boot from the CD ROM drive.  I know this is an older version and it seems to work with my arcade monitor, does somone recomend a newer better set up
compaq 500 ATI Rage Pro (pc running )
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: problem with Fraggal boot cd
« Reply #1 on: February 27, 2006, 01:28:50 pm »
It should only boot to an X: prompt if you still have the CD in the drive. Take the CD out and reboot.
POS
« Reply #2 on: February 27, 2006, 02:16:59 pm »
I have tried but says Abort, Retry, Fail.  It shows a c: but everytime I acess it wants to pull from the CD.
JoyMonkey
    • JoyMonkey.com
« Reply #3 on: February 27, 2006, 03:07:24 pm »
During the CDs install procedure, are you sure you created a primary DOS partition and formatted it fully?
POS
« Reply #4 on: February 27, 2006, 04:36:19 pm »
yes it did format.  using the format procedure that comes with the cd.  I used three different drives 1. drive had a linux program on it  i used Fragg's disk deleted non DOS part. formated and installed the programs.  when I rebooted it went to  a Grep prompt.  2. disk didn't work at all wouldn't format  3.disk is the one that i'm currently fighting.   do you have any recomendation on another setup. I just want somthing that will run with my arcade monitor and ArcadeOS runs well with my onboard Video ( ati rage pro)
JoyMonkey
    • JoyMonkey.com
« Reply #5 on: February 27, 2006, 08:49:24 pm »
I'd guess that the Linux drive probably has lilo on its master boot record, you need to remove it before the drive can be used with any other OS. I don't know a whole lot about Linux, but there's some instructions here:
http://www.control-escape.com/linux/lilo-cfg.html
Did the drive you're currently trying to use also have Linux on it?
POS
« Reply #6 on: February 27, 2006, 10:12:59 pm »
thanks for the tip.  I had to fdisk /mbr and it came up.  Now my monitor is no turning on.  I don't even get that static crackle sound from the tube.  I'm sure this could be one of a number os issues.  thanks again
POS
« Reply #7 on: February 27, 2006, 11:44:32 pm »
figured it out.  Bad crimp  on ac
