Author Topic: Donkey Kong problems  (Read 1437 times)
jimw
  • Last login:February 28, 2006, 04:56:57 pm
« on: February 26, 2006, 10:21:50 pm »
Running Mame 104 with mamewah 162 I can't get donkey kong working and could really use some help.
jim
HOTR6
  • Last login:November 13, 2006, 09:21:13 am
Re: Donkey Kong problems
« Reply #1 on: February 26, 2006, 10:39:49 pm »
It would help if you told us what wasn't working. I know there is a problem with some of the sounds and you need the sample for it. But I don't know if that is the problem you are refering to or not.
In short.......What is not working? What does it do?
cobey
  • Last login:April 20, 2006, 12:08:06 pm
« Reply #2 on: February 26, 2006, 11:24:47 pm »
also, does it work from the command line?
jimw
« Reply #3 on: February 27, 2006, 08:36:19 am »
sorry - My problem is the game will not load or run. The command window opens and then closes. I tried to launch from a command line and I get missing files but when I open the zip packet their all there. (I think I'm launching wrong from the comand line)  It used to work now it does not.
jim
cdbrown
  • Bowowow
« Reply #4 on: February 27, 2006, 11:25:17 am »
Do other games work?  If so then it's not config related.  If not then maybe mame isn't looking in the correct folder.  Does mame.ini point to the correct folder?
After running the game through the command promp (mame dkong) what are the messages you get?
