Author Topic: SF2 CE: Minor Graphical Glitches  (Read 2399 times)
« on: February 26, 2006, 03:22:04 pm »
Hey, I just got this board off fleabay...  works great, sound is good, the gameplay is fine, but sometimes sprites are missing in the game.  For example, sometimes pieces of legs are missing, sometimes portions of the lifebar disappear, and sometimes a number in the score will blink on and off.  Not always, its sort of a random occurance.  Has anyone else had this happen to them?  What can I do to fix this?
grantspain
Re: SF2 CE: Minor Graphical Glitches
« Reply #1 on: February 26, 2006, 03:26:43 pm »
sounds like your 5volts is a little on the low side,you should find no less than 5.10volts on the jamma connector board side,otherwise could be a poor connection on one of the eproms or board connectors,if its a rip off  board then they suffered problems like this all the time and there was not much you could do about it.
« Reply #2 on: February 26, 2006, 04:08:08 pm »
I have a SF2 CE that does the same thing because it is a hacked version. (I have red wave hack) The colors are sometimes off and spites error out sometimes. Just a side effect of the hack. I think you can look up the various SF2 hacks to see how you can tell. Mine changes what character you are playing as when you hit the start button. It of course could be a different problem, but go ahead and look up to see if you have a hack version. I think the klov has descriptions listed. ;)
