Author Topic: Request: VJB and Ultimate Arcade New Resolution for ArcadeCard  (Read 6173 times)
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
« on: February 18, 2003, 12:34:25 pm »
Is it possible to set up a resolution of 640x288 for both of these products?  This will be non interlaced for Andy's Arcade Card.  Thanks
VMJ Team
  • Last login:July 09, 2007, 09:29:50 am
    • Virtual Music Jukebox
Re:Request: VJB and Ultimate Arcade New Resolution for ArcadeCard
« Reply #1 on: February 19, 2003, 01:03:01 pm »
Both products were designed with the minimum screen resolution in mind 640x480.  Is there a specific feature or change that you had in mind?
You can either post here or mailto:info@cybertechdesign.net
yomero2k
  • Last login:July 12, 2004, 02:28:49 pm
« Reply #2 on: February 19, 2003, 04:44:13 pm »
while you are on it, would be grat if you could send the fullscreen video out on a secondary card or on the ttl video out from a ATI Radeon 9000 card, so we could use external monitor for the videos and, lyrics while using the main pc screen for music/videos selection  ;D
Superdude
« Reply #3 on: February 19, 2003, 06:10:00 pm »
Well on arcade on monitors and TV's we cannot use interlaced desktops.  It "flickers" alot.  We need non-interlaced resolutions.  IE 320x240 640x288 etc... It you maybe set something like 321x240 you could get a "flicker" free image on a tv or arcade monitor and the text would look alot better on small VGA monitors.  640x480 looks ok but it is not a stable picture.
VMJ Team
« Reply #4 on: February 19, 2003, 07:05:54 pm »
I see what I can do....I may not be able to get much smaller, but I'll try...as for dual monitors....
Currently, that is only possible on XP machines and I do plan on encorporating this feature in the near future....I first have to set up an XP machine and learn how to do this in code.
DJ Gary-N
  • Last login:April 11, 2004, 09:48:02 pm
  • Paul was the walrus
« Reply #5 on: February 19, 2003, 09:54:02 pm »
Also in VJB when I select Video in Left half of screen, It won't stay applied. as soon as I close out and restart it reverts back to Full screen. Just thought I'd bring it up.
Superdude
« Reply #6 on: February 20, 2003, 01:20:23 pm »
This is not a request needed immediately.  It's so that you product would also be more .... arcade friendly? I run your Jukebox with a monitor but I test it with my arcade cab.  I thought this might a great program to add to mame cabs.
