Author Topic: Dreamcast Mad Catz DreamPad and Happ's 360s  (Read 1971 times)
phantompower
  • Last login:June 14, 2024, 01:20:45 pm
  • The Game is NOT Over!!
    • MameStation
« on: February 18, 2003, 12:55:28 am »
Someone please help me put this to rest.  I have seen several sites and threads about the Happ 360s...most have been with regards to wiring a Playstation 2...
I cannot find any definitive help on how and where to wire the Perfect 360's  power on the Mad Catz controller.
Any assitance/images would be much appreciated.
Chuck
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Dreamcast Mad Catz DreamPad and Happ's 360s
« Reply #1 on: February 18, 2003, 02:26:01 am »
No offense, but is there some reason why you can't use a multimeter and find where the +5v is?  Regadless of which DC pad you have, there is +5 coming into it on pin 2 from the controller port.
http://mc.pp.se/dc/controller.html
phantompower
    • MameStation
« Reply #2 on: February 18, 2003, 08:14:07 am »
Dave,
No reason at all...outside of the fact that I have never used one before and don't have one.  In all of the projects I have done in the past, there has never been a reason to run power to a joystick.
Sorry if my question appeared to be the result of laziness.  Not my intention.
Chuck
« Last Edit: February 18, 2003, 08:16:42 am by phantompower »
SNAAAKE
  • -Banned-
MULTI METER question!
« Reply #3 on: February 19, 2003, 02:03:23 pm »
i got a ?.
How do you use multi meter ???
you touch some contacts and if the meter gives signal then i know its 5+ needed for the p360 joystick?
How do i know its not more then 5 volts?
anybody care to explain little bit more(Dave_k?)?
Also,what kind of multi meter is like the best?I wired p360 onces with a psx pad and the 5+ volt was writen on the pad(contacts).
But now i wanna do for dreamcast,psx pads ::).
« Last Edit: February 19, 2003, 02:07:55 pm by SNAAAKE »
hyiu
    • www
« Reply #4 on: February 19, 2003, 04:09:08 pm »
for normal uses... a cheapy radio shack DIGITAL multimeter should be good enough....
I got one for $20.... (I think.... don't remember for sure...)
they do quite a few different measurements.... currents.. DC,AC... etc...
you turn the switch and point the 2 metals to 2 points.. and they give you voltage... or Current... or whatever...
snaaake... if you got one and want to try... I guess safest and easiest is to point the 2 things to a battery... it should read 1.5V... haaa haa.... that should be the simplest example....
donno if this is any help...
I myself is looking into hacking a madcatz xbox ctrller for my friend.... but not using P360... so, no need for 5V....
good luck...
