Author Topic: Bought broken *used* X-Arcade solo...easiest fix?  (Read 2062 times)
csusjoe
  • Last login:March 04, 2006, 01:25:08 pm
« on: February 23, 2006, 05:11:54 pm »
I just bought a used X-Arcade solo at a local game shop for $15 and brought it home to find it broken. Would it be easier to see if I could get X-Arcade to work with me to get it fixed or should I just take out the X-Arcade board and install an IPAC (and maybe some better, less-clicky buttons)?? Has anyone replaced the X-Arcade board before?  Is there anything I should know?
Looking forward to spending more time on these super-informative boards!
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
Re: Bought broken *used* X-Arcade solo...easiest fix?
« Reply #1 on: February 23, 2006, 08:10:17 pm »
Email X-Arcade and ask them to see if they can identify the issue... might be an easy fix, or it might be a hard one.
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
Teebor
  • Last login:June 04, 2009, 12:39:06 pm
  • What does this button do??
« Reply #2 on: February 24, 2006, 04:31:26 am »
you will have to modify the wiring to work with the IPAC as the X-arcade has little white connectors on the end (or at least the couple I have seen do) which plug straight into the X-arcade board.
How was your french toast dear?
Smelly and ungrateful
-American Dad
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #3 on: February 24, 2006, 04:52:32 am »
How can anyone help if there's no definition of "broken" ???
Havok
  • Trade Count: (+17)
« Reply #4 on: February 24, 2006, 02:43:38 pm »
Doesn't matter. Chewing gum and duct tape will fix ANYTHING.
Just use that, and it will work...
« Last Edit: February 24, 2006, 05:00:00 pm by Havok »
csusjoe
« Reply #5 on: February 24, 2006, 08:01:22 pm »
"Broken" means not working when I try to plug it into any PC I have access to, nor to my XBox. The LED on the unit lights up, so do the LEDs on the connected keyboard, but none of the button presses on the unit cause anything to happen. When I try to switch modes and load the new mode using the button on the back, the LED on the unit is supposed to go off, but it doesn't. Therefore, it seems as if something is wrong with the board inside the unit.
And the wires are simply soldered onto the board inside the unit, no little white connectors as far as I can see...
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #6 on: February 24, 2006, 08:58:44 pm »
xarcade has a lifetime warrenty contact for warrenty repair
thanks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
