Author Topic: Advice needed for building Cabinet  (Read 2159 times)
NickC
  • Last login:January 10, 2010, 08:31:05 pm
  • Frosty!
    • Game On Webpage
« on: February 16, 2003, 05:11:30 pm »
Hello,
I am just getting into this whole scene, I was wondering what type of wood or other materials are best for building a cabinet, and how can i get that authentic look for a control panel, what materials are used? I am trying to build a two player setup, bought the parts from happs, are there any tutorials or plans for building a cabinet?
thanks
nick
ripzone
  • Last login:February 23, 2006, 02:28:01 pm
  • Pac-Mini coming soon...
    • RiP's M.A.M.E. Arcade Cabinet
Re:Advice needed for building Cabinet
« Reply #1 on: February 16, 2003, 05:40:34 pm »
I think the best to use is 5/8 MDF or particle board.
For the control panel the best is to use 5/8 plywood or MDF and a 1/8 sheet of lexan/plexiglass!
You can go to the Examples section at http://www.arcadecontrols.com to find good plans!  ;D ;D
If you have any more questions, just ask!  ;D ;D ;D
NickC
  • Frosty!
    • Game On Webpage
« Reply #2 on: February 17, 2003, 12:03:24 am »
The size for the pushbutton holes is 1 1/8 inch correct? what is the size of the joystick hole, the same or larger?
cdbrown
  • Bowowow
« Reply #3 on: February 17, 2003, 03:00:38 am »
Most people just use the same hole cutter for the buttons and joystick which saves money.  The limiting factor on the hole size is the overall thickness of the panel (including lexan).  The deeper the bigger the hole size as you don't want the stick to hit the wood.  Most examples I've looked at have the overall thickness as 3/4" and 1 1/8" hole.  Just make sure you have the joystick centered on the hole.  On my cheap trial panel one of the joysticks is off center and hits the wood very slightly.  It still registers the movement but you can tell it doesn't move as far in that direction.  If you're worried and have the money then go for 1 1/4" just to give a little more room.
*Edit - don't make the hole too big that you need a new disc
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=5021
Cheers
-cdbrown
« Last Edit: February 17, 2003, 03:08:40 am by cdbrown »
Jakobud
  • Last login:May 25, 2026, 02:04:14 am
« Reply #4 on: February 17, 2003, 04:17:52 am »
5/8" MDF will serve you well.  Almost all my panels are this and it looks incredible.  Very nice finish after painting.
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #5 on: February 17, 2003, 01:00:00 pm »
Everything everyone else said, *and* thicker materials require bigger holes for the joystick. I use a 1.5" bit for all my joysticks. Spade tip bits are pretty cheap. Maybe $2 or $3 each.
Bob
