June 06, 2026, 11:48:30 am
In MAME there are no games that require 7 buttons. The 7 button layout is so that you can play 6 button fighters or 4 button Neo-Geo games comfortably as they were on the original cabs. There are absolutely NO 4-player games in MAME that use more than 4 buttons (I think it's actually 3). The only reason to use more than 4 buttons on players 3 & 4 is if you are using consoles in which case you may need as many as 8 buttons per player.
Quote from: markrvp on February 19, 2006, 07:54:32 pmIn MAME there are no games that require 7 buttons. The 7 button layout is so that you can play 6 button fighters or 4 button Neo-Geo games comfortably as they were on the original cabs. There are absolutely NO 4-player games in MAME that use more than 4 buttons (I think it's actually 3). The only reason to use more than 4 buttons on players 3 & 4 is if you are using consoles in which case you may need as many as 8 buttons per player.Gotcha! So if am thinking of emulating is it even worth putting 6 on since I'd probably need 8 anyways? Thanks for the input guys
