Author Topic: plunge router vs standard router  (Read 2501 times)
Firebaall
  • Last login:May 01, 2011, 11:26:24 am
« on: February 15, 2003, 03:46:10 pm »
Hey all,
Can anybody let me know what the difference between a standard router, and one with plunge capabilities?  I'm shopping for one to finish up a cab that I'm restoring.
-FB
Larry Smith
  • Last login:September 01, 2004, 07:27:11 am
Re:plunge router vs standard router
« Reply #1 on: February 15, 2003, 04:40:59 pm »
a plunge router is one that lets you change the depth of the hole on the fly. Its saves you from making a starter hole.
donniet
  • Newbie
  • Last login:February 02, 2003, 05:54:30 pm
« Reply #2 on: February 15, 2003, 04:42:07 pm »
A plunge router is easier (and safer) to make a cut anywhere in the middle of a board.
Personally I find it easier to set the depth of cut on a plunge router than a fixed base.  Fixed bases are usually easier for doing edge work since they arent as tippy as plunge based routers.
I own two plunge routers because they were the best deals when I was purchasing, but I have been looking for a good excuse to add a fix based to the collection.
To me, the most useful features that can be added in routers is variable speed and 1/2 collet.  Both are good features because of safety.  1/2 bits are stronger and variable speed is needed for large diameter bits.  Tip speed gets really fast when you have a 2 inch+ bit spinning at 22k rpm.
Donnie
schwefeljm
  • Last login:February 06, 2003, 02:24:36 pm
« Reply #3 on: February 15, 2003, 05:44:30 pm »
Donnie
Very true, very true.
Just how fast does the bit travel you ask, well, I will tell you
360o = 2 * pi Radiens (rads)
1 rad = the distance traveled, along a circle, equal to the radius of the circle
So, to find the distance that point X on a router bit travels during on revolution, take the radius of the bit, multiple by 2pi
In the case of a 2" bit, we get (rounded) 6.3 in/revolution
at 22,000 RPM that equals 138,630 inches/minute
ok, that is fast, but no one deals in inches/minute, so we convert to MPH
138,630 * 60 (minutes in an hour) = 8,317,800
8,317,800 / (5280 [feet per mile] * 12[inces per foot]) [inches per mile] =  131 MPH
130 MPH, now that is fast. if we increase that to a 2.5" bit, we get 163 MPH
33 MPH dif for just an extra 0.5"
That is why it cuts wood so smooth.
Jason
RoadhawK
  • Last login:May 29, 2023, 02:15:28 pm
  • Arcade Junkie :)
« Reply #4 on: February 15, 2003, 07:21:40 pm »
 :D Exquisitely put and very interesting. If i'm honest numbers terrify me but i can usually get there in the end  ;D
Firebaall
« Reply #5 on: February 15, 2003, 10:56:17 pm »
Heh,
Thanks.
Found out Sears is having a sale next weekend, and the plunge model that sells for $400CND is gonna be half price.....guess that settles it.  :)
Firebaall
« Reply #6 on: February 15, 2003, 10:58:58 pm »
Opps, before I forget......
I want to counter sink a kickpanel ( 1/8" sheetmetal ) around the base of the cab.  From what I gather a rabbiting/straight bit is the way to go.  Yes?
eightbit
  • My cab is never done...
« Reply #7 on: February 16, 2003, 05:12:38 pm »
Make sure its a plunge or bottom cutting bit.
