July 07, 2026, 09:05:53 am
The mame folder which contains everything else (mame.exe) etc is on the C:\ how do i tell mamewah where the xml folder is (where is the default location that mamewah will look?).
Do I need to have the rom folder in with the mame folder for it to work?
### 01mame.ini (mamewah v1.61) ###emulator_title M.A.M.E.### List Generation Settings ###rom_path d:\romsrom_extension zipdat_file nms_file catver_ini_file c:\mame build\mame\catver\catver.inilist_generation_method rom_folder_vs_listxml### Execution Settings ###emulator_executable c:\mame build\mame\mame.execommandline_format [name]{autodosbox}{nosafelaunch}alt_commandline_format_1 [name]{autodosbox}{nosafelaunch}alt_commandline_format_2 [name]{autodosbox}{nosafelaunch}game_specific_config_path ### Artwork Locations ###artwork_1_image_path d:\snapartwork_2_image_path d:\marqueesartwork_3_image_path d:\artworkartwork_4_image_path artwork_5_image_path artwork_6_image_path artwork_7_image_path artwork_8_image_path artwork_9_image_path artwork_10_image_path movie_preview_path d:/mame/moviesmovie_artwork_no 1### Screen-Saver Settings ###enable_music_in_screensaver 1saver_type moviemovie_path d:\mame\moviesmovie_fullscreen 1quit_delay 30wrapper_executable wrapper_commandline_format [name]{nodosbox}{nosafelaunch}scr_file ### External Application Settings ###ipc_file_or_path app_1_executable app_1_commandline_format app_2_executable app_2_commandline_format app_3_executable app_3_commandline_format auto_launch_apps ### Additional Settings ###music_path lcd_display_file_path lcd_fe_text ### Settings used by MAMEWAH ###current_list 1
I created a listxml using the command line - I have it set-up the emulator.ini file as rom_folder_vs_listxml, but when I load mamewah I cannot filter the lists at all.
