Author Topic: Mamewah-merge or unmerge roms  (Read 1542 times)
ojelela
  • Last login:May 16, 2007, 09:59:37 pm
« on: February 13, 2006, 09:56:34 pm »
Hi
I did some search on this topic but most of them are old like 2003, I'm getting my roms set but I believe they are gonna be all merged sets. I will use Mamewah so I was wandering if any of those previous posts still valid, I mean is it that Mamewah does not like merged sets, and is romcenter still easier to use then clrmamepro or is there something new available to unmerge roms?
You best bet is to split it with romcenter btw, it's much easier to use then clrmamepro.
Mame won't care, but just about every fe out there will.  Windows front-ends don't do crc checks.
If you have merged roms, unmerge them. Mamewah doesn't like merged roms.
Re: Mamewah-merge or unmerge roms
« Reply #1 on: February 14, 2006, 05:30:50 am »
Since MAME removed the 'verifysets' switch, it is harder for FE's to recognise merged sets.  However, I always recommend using split sets anyway, as it just causes less problems generally.
Personally I would use ClrMAMEPro to do the job...you can take your pick :)
ojelela
« Reply #2 on: February 15, 2006, 12:17:40 am »
Thanks Minwah, I received my set's today, 10 dvd's mame, 9 daphne, 4 VP I guess I'll be busy for some time.
