Author Topic: SUCCESS! - Start/Test CP is working!  (Read 1232 times)
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« on: February 11, 2006, 12:56:01 pm »
Woo Hoo.
Got my 6 buttons and Joystick yesterday so I put together a starter panel to play around with.  And woo hoo, everything worked on the first try.
Had to go buy a 1-1/8" spade bit to drill the button holes.  Then used a Holw saw to drill a starter hole for the joystick and filled some edges to get it to fit.
Wiring up everything was a piece of cake.  Just used Cat5 cables and pulled them apart.  Used orage for the buttons, Green for the joystick and white/gray for the grounds.
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
Re: SUCCESS! - Start/Test CP is working!
« Reply #1 on: February 12, 2006, 02:00:30 am »
if you start having problems with intermittent connections, check those wires first.  I ended up having to redo my WHOLE control panel ( a 4 player beast with a retarded number of buttons) because I used cat5 cable which as you know is a solid wire.  Doesn't always stay in place in a crimped situation as a stranded wire.
just an FYI.
Allroy
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
kelemvor
« Reply #2 on: February 12, 2006, 09:00:26 am »
Thanks for the tip.  I took some advice I had seen here and bent the end of the wire over before I crimped it in the connector so hopefully that will keep it in there nice and tight.
