Author Topic: What Do I Need to Change  (Read 1063 times)
JustPassinThru
  • Last login:November 17, 2011, 04:05:44 pm
« on: February 09, 2006, 07:51:42 pm »
I was hoping that someone could help me out with my controller configuration. On some of my games the buttons don't work. I know they're hooked up right because on other they work fine. The best I can determine is it's in the game setup. My problem is once I enter the Tab/config screen I can't move down to change any settings. Neither the arrows or joystick will work to move down. Is there something I can do to change the setup? Either in individual games or a custom controller configuration? Maybe a way to set default setup for all games that I don't know about??? I tried resetting the non working games to default settings with no luck. I would appreciate any help because Wrestlefest and Tecmo Bowl are calling me!  :) Thank You!
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
Re: What Do I Need to Change
« Reply #1 on: February 09, 2006, 07:55:27 pm »
Plug in a keyboard and try using that to move around.  THen try to change some settings and set them with the joystick or button and see what letter shows up.
