Author Topic: Swapping motherboards and Windows XP?  (Read 10468 times)
Otraotaku
  • Last login:May 17, 2025, 05:38:18 am
  • トラビス
« on: February 08, 2006, 06:35:09 pm »
im planning on buying a new motherboard... but im pretty sure if i swap out a motherboard for another i wont be able to use the Windows XP on my hardrive... is this true in cases? and any (expereinced) alternative to keeping an OS and not paying another $$$ to M$?
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re: Swapping motherboards and Windows XP?
« Reply #1 on: February 08, 2006, 07:00:06 pm »
Might work..
Depends on chipset..
Most likely, youll have to reactivate windows, and reinstall chipset drivers..
Otraotaku
  • トラビス
« Reply #2 on: February 08, 2006, 07:02:16 pm »
Might work..
so you mean, (if the manufacture of my old computer had windows installed i would be SOL?)
SOAPboy
  • ..::GeeK::..
« Reply #3 on: February 08, 2006, 07:07:26 pm »
Might work..
No..
Im saying youll have to reactivate windows, and reinstall chipset drivers..
Absolute worst case, youll be reinstalling windows..
Pirate copy?
Otraotaku
  • トラビス
« Reply #4 on: February 08, 2006, 07:09:00 pm »
Might work..
No..
Pirate copy?
*Edit* no, its a manufactures Reinstall CD
« Last Edit: February 08, 2006, 07:35:15 pm by Otraotaku »
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
« Reply #5 on: February 08, 2006, 07:29:30 pm »
I think he was asking you if your copy of xp is pirate. (This may go post hell soon :) )
If it is, you don't have to worry about activation.
As far as re-installing when installing a new MB, definitely positively a great idea.
Unless you're replacing the MB with an identical model.
Now in a tasty new flavour.
Otraotaku
  • トラビス
« Reply #6 on: February 08, 2006, 07:31:35 pm »
im just very worried about having to get another copy of Windows XP after Purchasing almost 400$ worth of hardware... :P (and id like to have a backup plan if it does)
SOAPboy
  • ..::GeeK::..
« Reply #7 on: February 08, 2006, 07:41:46 pm »
If its an HP or Compaq, or sony, ect prebuilt PC reinstall disc, guess what, you have to buy windows again if you replace that motherboard.. :(
Otraotaku
  • トラビス
« Reply #8 on: February 08, 2006, 07:49:49 pm »
 :-X thats kinda what i meant by manufactures... >.< looks like im gonna have to go down the dark path on this one...  :-\
SOAPboy
  • ..::GeeK::..
« Reply #9 on: February 08, 2006, 07:54:33 pm »
Spend the 100 bucks man.. its worth it to be fully updated..  :P
Otraotaku
  • トラビス
« Reply #10 on: February 08, 2006, 08:00:46 pm »
im still in HS, no car no job... (no more $)  :laugh: heh
SOAPboy
  • ..::GeeK::..
« Reply #11 on: February 08, 2006, 08:04:35 pm »
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #12 on: February 09, 2006, 01:23:10 am »
once you get out of HS you have a job and car but still no $ ....
AtomSmasher
    • Atomic-Train
« Reply #13 on: February 09, 2006, 02:02:00 am »
If you change the motherboard then you will not be able able to boot, you will get a blue screen of death everytime windows tries to startup.  The only time this won't happen is if you replace your motherboard with the same motherboard (as in your old mobo went bad so you got a new one), or it might still work if it has the same north and south bridge on the mobo, but I doubt thats what your doing.
In other words, if your goal is upgrading your computer, then yes, you will need to reinstall windows.
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« Reply #14 on: February 09, 2006, 03:23:53 am »
Actually, he doesn't have to reinstall Windows even if the motherboard is different. I did a similar thing on Windows 98! But I got through it. XP is generally better at handling driver conflicts than older versions. The first few boots will be a pain in the ass. But once Windows finally resets all the drivers, you should be good to go. I have had it work before. Like I said, though, it is a pain.
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
AtomSmasher
    • Atomic-Train
« Reply #15 on: February 09, 2006, 03:54:07 am »
I've tried it 3 or 4 times on different computers and it never worked, always immediately went to blue screen of death, couldn't even get to the "boot to safe mode" menu.  Also at a job I had we had about a dozen computers and harddrive images backed up for each computer.  If you loaded the wrong image onto a computer then you would also get the BSOD.  It may be possible to make it work, maybe boot with a recovery disk and change the drivers around manually somehow, but it wouldn't be easy.
jbox
  • BYOAC Poet Laureate
  • Last login:November 30, 2007, 08:00:54 am
« Reply #16 on: February 09, 2006, 04:16:21 am »
it's hit and miss. one has worked for me, a couple didn't. I find deleting every single device in the device manager before you swap over helps a bit.
Done. SLATFATF.
USSEnterprise
    • USS Odyssey
« Reply #17 on: February 09, 2006, 04:20:40 am »
It definitley isn't easy. It took me 2 full days to get it running smoothly, but it saved me $100. One thing I recommend before tearing the computer apart, if you haven't already, is to go into device magager and delete as many drivers for devices as you can. The transition will be easier
jbox
« Reply #18 on: February 09, 2006, 04:41:15 am »
<edit - didn't say anything useful (as usual), and it turned out to be not so funny once sober - sorry Enterprise :)>
In summary, since you have one legal license just get yourself a corporate edition from somewhere and be done with all this frickin' kerfuffle.
« Last Edit: February 11, 2006, 09:24:47 pm by jbox »
Done. SLATFATF.
SOAPboy
  • ..::GeeK::..
« Reply #19 on: February 09, 2006, 07:35:48 am »
This isnt win 98.. he will have to reactivate windows..
XP boots.. and itll run ok.. but far from great most of the time..
But saying if you swap the mobo you cant get it to boot is bs.. its possible..
Failsafe way of doing it.. Totally uninstall EVERY driver for your chipset, ide drivers, and onboard sound drivers.. power down, swap mobos, slap new one in..
Again, still have to activate again, but itll be a bit more stable that way..
Harry Potter
  • Smite-bait
« Reply #20 on: February 09, 2006, 11:00:39 am »
You can get it to boot, but it'll be unstable as all hell at best. I tried this a few time and it wasn't worth it. Besides, re-installing takes a few hours. Using this slacker method will just cause more problems in the long run and he'll have to re-install anyway.
It's not those that matter. It's chipset drivers, APM drivers and any core system drivers that are important and these don't come on installation disks. They come with XP/2000/whatever.
USSEnterprise
    • USS Odyssey
« Reply #21 on: February 09, 2006, 12:01:50 pm »
How old is your copy of XP? I thought you didn't have to activate XP until SP2 came out? Additionally, if you have 2000, thats just as good, if not better. Not Millenium, though.
Harry Potter
  • Smite-bait
« Reply #22 on: February 09, 2006, 12:05:46 pm »
XP required activation from day one. Australia was the first to try this out. It was a miserable mess.
SOAPboy
  • ..::GeeK::..
« Reply #23 on: February 09, 2006, 12:22:41 pm »
Did you even read what i said? lol
Chipset, Ide, ect.. all drivers related to the motherboard..
SOAPboy
  • ..::GeeK::..
« Reply #24 on: February 09, 2006, 12:30:13 pm »
Since beta theres been activation.. only copys that didnt have it were corp multi license copys..
USSEnterprise
    • USS Odyssey
« Reply #25 on: February 09, 2006, 01:04:49 pm »
Has anyone here ever tried ReactOS? Its made to be compatible w/ XP, but is legally free.
AtomSmasher
    • Atomic-Train
« Reply #26 on: February 09, 2006, 01:39:04 pm »
Well I'm just telling what I've learned from my experience.  As I've said I've tried it a number of times and I've never gotten it even close to booting up.  Granted I never uninstalled all the old drivers first and didn't try very hard to install new drivers, but since I was never even able to make it to the boot to safe mode menu, I figured it wasn't worth my trouble and just reinstalled.
SOAPboy
  • ..::GeeK::..
« Reply #27 on: February 09, 2006, 01:57:05 pm »
Yeah, first time i ever did that i did the same thing..
Just gotta remember to uninstall drivers before you swap mobos :)
mrhowell
  • Last login:August 01, 2025, 09:42:31 pm
« Reply #28 on: February 09, 2006, 04:09:08 pm »
One of the nicer benefits of working in the K-12 environment,  unlimited software.  Windows XP, Server 2003, Netware w unlimited license,  Office 2003,  Pagemaker, Photoshop, etc.  If I could only get the school system to do a gaming class.  I need a copy of Call of Duty 2.  As for your problem, just make good backups of anything important like saved games and such.
What is that pappy?
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
« Reply #29 on: February 09, 2006, 05:22:16 pm »
I wrecked the BIOS on my MB about 2 weeks ago (i'm retarded) and I got a new mobo, different manufacture, different processor, booted up....worked fine
XP SP2.
that's just my experience though.
Allroy
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
USSEnterprise
    • USS Odyssey
« Reply #30 on: February 09, 2006, 06:08:26 pm »
XP SP2.
Allroy
You wrecked the BIOS? Did you try flashing it?
SOAPboy
  • ..::GeeK::..
« Reply #31 on: February 09, 2006, 06:08:38 pm »
XP SP2.
Allroy
Chipset might of been the same, or same brand ;)
Otraotaku
  • トラビス
« Reply #32 on: February 10, 2006, 01:07:06 pm »
which drivers are you  exactly talking about? and where from device manager?
USSEnterprise
    • USS Odyssey
« Reply #33 on: February 10, 2006, 02:14:35 pm »
I advise that you boot insto Safe Mode (F8) before doing this:
Start  >> Control Panel >> System >> Hardware Tab >> Device Manager
Expand all the devices. Right click on each and select uninstall.
When it asks you to confirm, click yes. If it tells you to restart, don't, and continue removing devices until most, if not all of them are gone.
Even though I am pretty sure this will work, I will not be held responsible if it ---smurfs--- up your computer :)
Harry Potter
  • Smite-bait
« Reply #34 on: February 10, 2006, 08:24:29 pm »
Core drivers (ie most chipset drivers) cannot be uninstalled without severe damage to the OS. Yes I did read. lol
SOAPboy
  • ..::GeeK::..
« Reply #35 on: February 10, 2006, 09:14:51 pm »
Sigh..
yes they can.. they were installed AFTER you installed the OS..  Not durring.. Only time this isnt true is if your running SATA drives with onboard sata..
Otraotaku
  • トラビス
« Reply #36 on: February 10, 2006, 10:20:00 pm »
im going to go ahead and get my new pc parts... and pray to god i can back away from the consequences,... I also have a backup plan now  ;) if ya know what i mean
« Last Edit: February 10, 2006, 10:21:55 pm by Otraotaku »
USSEnterprise
    • USS Odyssey
« Reply #37 on: February 10, 2006, 10:56:08 pm »
That backup plan, if I catch your drift, has worked well for me in the past. Just look out for versions that aren't in another language. Installing Windows in Russian wasn't fun.
AtomSmasher
    • Atomic-Train
« Reply #38 on: February 11, 2006, 01:13:30 am »
Hehe, in the job I mentioned that had a dozen computers with hard drive images for each one, when I worked there they were switching to a unicode software design so their software should be compatible in all languages.  Well it became my job to install windows and create a harddrive images for each machine in the languages of chinese, spanish, and a third one I can't seem to remember.  Needless to say I got pretty good at installing windows with having no idea what the buttons say.
rugby1
  • Last login:April 12, 2007, 12:10:12 am
« Reply #39 on: February 11, 2006, 01:39:03 am »
there are ways around the activation in XP.... search for a program called RockXP....  When you activate windows online, it writes a file to your C:\Windows\System32 folder.  Rock XP lets you copy this file (from the old system) and then put it back in your System32 folder (on the new system)....   I have never tried it but in theory it should work....
RockXP allows you to retrieve your XP product key that you used when you installed Windows XP, as well as keys for other Microsoft products. This can come very handy if you need to reinstall but have misplaced or lost the CD cover with the serial sticker. In addition, the program also lets you save the product activation to a file, and enables you to recover usernames and passwords contained in the Windows Secure Storage.
