Author Topic: Quick question about common ground wiring.  (Read 2278 times)
Jae200
  • Last login:February 15, 2006, 03:55:46 pm
« on: February 05, 2006, 11:41:34 pm »
Hi everybody. I'm expecting (I hope!) to get my IPAC2 encoder and plan on wiring up my control panel tomorrow. I did alot of reading here and on the Ultimarc site to learn how to do this since I've never done anything like this before. My question is about the common ground. I understand that most people daisy chain from one button to another.. Do you use 1 long piece of wire and strip off some insulation where your contact point is and run it to all the buttons or do you use a small piece of wire between each button, or does it even matter? I'd like to go the quickest and easiest way since I have someone coming over tomorrow night and would like to have the thing wired up so I can give a demonstration. I'm not planning on soldering.. I ordered the wiring kit with push on connectors. Also, it makes no real difference whether I 'complete the loop' back to the ground on the encoder right? That is, its not necessary? I ask because if things take a little longer than I expected, I may just wire up the player 1 controls for now just to get the thing up and running. Looking forward to it since this is all thats left before my project is finished! Thanks.
SirPeale
  • Green Mountain Man
Re: Quick question about common ground wiring.
« Reply #1 on: February 05, 2006, 11:56:38 pm »
It doesn't matter how you do it.  I prefer to have seperate pieces of wire because it's easier for me to do that than removing the insulation between two buttons.  But that's me.
AtomSmasher
    • Atomic-Train
« Reply #2 on: February 06, 2006, 02:06:41 am »
I also did seperate pieces of wire.  Don't know how much it'll help you, but when I was building my first cab, issue #4 of www.retrorevival.co.uk answered all my ipac installation questions.
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: February 06, 2006, 08:04:51 am »
Main advantage is that this gives you a shorter path and less total wire used.  Other advantage is that you don't need a terminal block to take 28 wires into one or two terminals.  (Some say troubleshooting is easier, but that's not really the case).
For solder connnections, it's probably easier to use one long wire, and strip the insulation between each joint.  For crimp connections, it's easier to use individual pieces of wire.  In other words - Strip insulation and screw wire into ground terminal.  Route a little bit past Button 1 microswitch, cut and strip insulation (about 1/4-inch from end).  Cut and strip 1/4-inch insulation from wire spool and crimp to wire from ground terminal.  Plug connector onto microswitch.  Route a little bit past Button 2 microswitch, cut and strip insulation . . .  (Also, you want the shortest path, not necessarily Button 1 to 2 to 3 to 4 to 5.  You can use multiple daisy-chains if that is easier, more convenient, etc.)
The advantage of completing the loop is as follows:
Open Loop - One break in a wire and all buttons "downstream" of the break stop responding.
Closed Loop - One break in a wire has no effect.  Two breaks and some "group" of buttons will stop responding.
However, remember that the wire and crimp connectors are not reusable - i.e. if you go the open loop method to save time (only missing one wire segment) and then want to "close the loop" you will have to cut off the last terminal and replace it.  If you barely had enough wire to reach the switch, it might not reach after you cut it off, so you have to replace the last two connectors, and so on . . .
maxlamer
  • Last login:June 20, 2006, 09:45:12 am
  • I like stuff
« Reply #4 on: February 06, 2006, 08:08:55 am »
i used one wire and striped the insulation where needed, i found it faster and easier that way
Capthowdy
  • Last login:April 13, 2015, 03:33:18 pm
« Reply #5 on: May 06, 2006, 05:55:46 am »
are player 1 and 2 linked into the same chain?  or do most people use a separate chain for each player?
SirPeale
« Reply #6 on: May 06, 2006, 06:34:19 am »
They could be, but don't have to.
Capthowdy
« Reply #7 on: May 06, 2006, 01:38:41 pm »
ok...then I think i'm going to keep them separate...and not complete the chains.
thanks
