Author Topic: serious problem with my mame box!!! help!  (Read 1588 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« on: February 04, 2006, 01:47:55 pm »
okay, i have been following one of the tutorials on here on how to mask windows.  i got rid of the status messages and i recently changed my boot background to 0 0 0 in the registry.  this morning i turned it on and it took forever to boot into mamewah.  i did some searching on the board and i found this
http://forum.arcadecontrols.com/index.php?topic=45930.0
seems like this was happening to me as well....the long boot up.  however, i turned it off, and then came back to it and now it hangs and i cant boot into mamewah.  i get to the windows xp loading screen, and after thats done it goes black and sits there.  like nothing is happening.  ive tried to boot into safe mode, but when it starts loading all the drivers (you know when all the text starts rolling on the screen) it freezes after like 15 lines of text.  the num lock light goes out on the keyboard and i cant do a ctrl alt del.  whats the deal?  i have guests coming over tomorrow for the super bowl and i need to have it working!  help!!
hulkster
Re: serious problem with my mame box!!! help!
« Reply #1 on: February 04, 2006, 01:56:58 pm »
okay it finally came up, but i think i'm having the same problem that guy in that link.  im afraid to go messing around too much as my guests will be here tomorrow night.  anyone have any sure fire suggestions?
hnugz
  • Last login:September 14, 2013, 06:18:38 pm
    • Horrorcore Games
« Reply #2 on: February 04, 2006, 05:58:37 pm »
try running the windows recovery option off of the winxp cd.  put it in, boot to the cd, and then run recovery console or whatever.
what all did you change from the time it was working to the next time?  only the 0 0 0 in the registry?
You could also try running last known good configuration if you have that option from the boot menus.
"Don't play pinball if you only got one arm, cuz your score will suck."
hulkster
« Reply #3 on: February 04, 2006, 07:10:53 pm »
well i tried that, but it still takes forever to boot.  i mean, it eventually comes up and i get back in to windows, but it takes a while for it to come up the first time.
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
« Reply #4 on: February 04, 2006, 07:51:09 pm »
Try booting into safe mode and choose the step by step option. You should be able to see each component and driver loading individually and identify whats causing the problem.
I didn't touch it....honest!
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« Reply #5 on: February 06, 2006, 07:48:54 pm »
If this box just runs mame, might be faster to just reload windows than try to troubleshoot it...
I have Windows on C and everything else (Mame, Roms, etc) on D so killing C is no big deal.
Will probably even make an image of C after a fresh load and update so reloading will be even faster.
