Author Topic: Weird Mortal Kombat glitch  (Read 2794 times)
« on: February 02, 2006, 11:38:56 am »
When I start my MK up, it runs through the normal rom checks, then gets to the screen where it says Midway Presents, the music starts to play, and then everything will reset back to the initial rom check screen.  However, if you have credits on the machine, and keep hitting start as Midway Presents is coming on the screen, you can play normally.  Any idea what may be causing this problem?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Weird Mortal Kombat glitch
« Reply #1 on: February 02, 2006, 12:05:24 pm »
test mode switch is turned on. (?)
NO MORE!!
grantspain
« Reply #2 on: February 02, 2006, 04:48:34 pm »
good to check your 5v on the jamma set to about 5.10 but check on the board side,is it a rip off mortal kombat because all of those suffered voltage and ic socket problems.
fredster
  • It's all good!
« Reply #3 on: February 02, 2006, 04:58:53 pm »
I agree. IT NEEDS MORE POWER
« Reply #4 on: February 03, 2006, 05:26:34 am »
Nope, it's off...  I'll poke around in there today and test the voltages.  And no, it's not a rip-off MK, it's an original.
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #5 on: February 03, 2006, 02:07:47 pm »
Bad power supply?
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
