Author Topic: Mamewah As Frontend - Have I Cocked Up!  (Read 3320 times)
M.A.M.E Power
  • Last login:February 06, 2007, 04:25:59 pm
  • There Are So Many Games!
« on: February 01, 2006, 10:52:47 am »
Ok have been configuring my PC for use in my cabinet, have done everything now - the last thing to do was set Mamewah as the shell.
Set it as the shell and works fine - but i cannot access windows now through that user account.
I can still access all i need through the admin account, was just wondering if it is normally done this way (i.e two accounts).
I guess it would be useful to be able to gain access to windows via the mamewah user account.
I await your knowledge!
Lea
Farmboy90
  • Last login:June 26, 2006, 12:15:04 am
  • My cab is done... Pics coming soon!!
Re: Mamewah As Frontend - Have I Cocked Up!
« Reply #1 on: February 01, 2006, 10:55:50 am »
I don't think I understand what you did here.  When I set up my PC, the initial user account created had admin rights.  That is the only account needed.
I installed MameWAH and set up it.  Just drag and drop the MameWAH.exe into your startup folder.  Set XP to auto-login for you, and voila!  Every time your PC comes on, it will log itself in and launch mamewah.
2600
« Reply #2 on: February 01, 2006, 11:07:09 am »
That is the point of a shell.  To allow you to do all the "windows" stuff.
Changing your shell to MAMEWAH means you chose to run MAMEWAH only.
However, there should be a way out. Directions may differ due to OS.
1. Alt-Ctl-Del
2. Task Manager
3. File -> Run
4. Type explorer
I "think" MAMEWAH has this ability to app_to_run_on_exit.  If you put explorer in there, when you exit MAMEWAH this should run.
Farmboy90
« Reply #3 on: February 01, 2006, 11:08:52 am »
I can do all the windows stuff.  I just hit ESC when in Mamewah and it takes me back to windows.
2600
« Reply #4 on: February 01, 2006, 11:14:18 am »
You also aren't running MAMEWAH as your shell.
You are running it like any other application which you are right it works just fine.
M.A.M.E Power
« Reply #5 on: February 01, 2006, 11:15:43 am »
I have set it up so it loads straight until Mamewah and it works great.
2600 thanks for the get out, worked fine.
Can you please post the location of the explorer.exe so I can put it into the Mamewah.ini file so it runs that on exit.
Many thanks
Lea
2600
« Reply #6 on: February 01, 2006, 11:19:51 am »
Many thanks
Lea
Seriously, you are not the type of user that should be setting apps to the shell.
Get off your but and use windows search to find it.
M.A.M.E Power
« Reply #7 on: February 01, 2006, 11:29:16 am »
Well it all seems to be working well so far.
I tried the default location C:\WINDOWS\EXPLORER.EXE
For some reason that does not work, even though that is the location.
2600
« Reply #8 on: February 01, 2006, 11:33:43 am »
Did you change exit_action?
Flinkly
« Reply #9 on: February 01, 2006, 11:37:20 am »
sorry to write a bit off topic, but if you shell mamewah, and quit mamewah when your done gaming, does the comp just turn off?  and if you did want to do some changes to your setup, how would you go about getting back to windows?  could you stick windows in as an app that mamewah can start within itself if you needed to make changes?
i understand the basic workings of shelling, but i don't really want windows to start up everytime i go to turn off my cabinet.
« Last Edit: February 01, 2006, 11:54:14 am by Flinkly »
M.A.M.E Power
« Reply #10 on: February 01, 2006, 11:38:19 am »
No what do I have to alter that too, in order for it to run explorer.exe on exit.
All help is appreciated.
Lea
« Reply #11 on: February 01, 2006, 11:51:51 am »
Set:
exit_action run_app
...and:
exit_and_run_app_commandlines c:\windows\explorer.exe
OR you could just set:
exit_app_commandlines c:\windows\explorer.exe
