Author Topic: ? for Ken  (Read 1449 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
? for Ken
« on: February 01, 2006, 01:11:23 am »
Ken I see you are browsing the boards so I thought I would ask you a couple of questions.
I have a U3100 which has a sync range of 31-35kHz.  I was wondering if I could damage it by sending it a sync of 29kHz?
The other question I had was regarding a Neotec NT25E monitor.  Does it require an isolation transformer?
Thanks for your time.
Ken Layton
  • Guru
  • Technician
Re: ? for Ken
« Reply #1 on: February 01, 2006, 01:37:55 am »
I have never worked on or seen a U3100 so I can't answer that question as I have zero wexperience with that model.
I believe that particular Neo-tec does not need an isolation transformer. Best to check with the manufacturer at www.neotecgraphic.com
