Author Topic: Console emulator screenshots  (Read 1592 times)
teebishop
  • Last login:March 15, 2006, 11:57:20 pm
« on: January 27, 2006, 03:15:25 pm »
Is there a way to change all the screenshot file names easier than just doing it manually? I dont really like the goodnames naming system, because i dont want all the (U)(!) stuff at the end of the game names is MAMEWah. I just want the name of the game. So is there software, or something out there that will maybe take a screenshot of all my games and name the screenshot accordingly, or a program that will rename all my screenshots to the same name as the game files, or am I just kinda stuck renaming EVERY file I want changed?
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
Re: Console emulator screenshots
« Reply #1 on: January 27, 2006, 04:46:06 pm »
you could search the boards for for something like that. I know I something like that
teebishop
« Reply #2 on: January 28, 2006, 01:20:35 pm »
i have tried that, but i cant find anything! anybody else got any suggestions?
math0ne
  • Last login:January 21, 2025, 04:50:16 pm
« Reply #3 on: January 28, 2006, 05:40:03 pm »
If you already have your games named the way you want your could use gameex to take screenshots for you.
Alternatvly you may be able to make a macro ro acomplish this depending on your games and screensshots.
math0ne
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #4 on: January 28, 2006, 10:17:17 pm »
There's an app called renameman that will rename masses of files, but I don't think it will help you.  I have used it for renaming sequential images for making video.
The reason I don't think it will help you, is because it's not all that smart.  It want's all of the files that you're renaming to be named similarly already.  For example it's good at taking files called something like animation0001 and renumbering all of the images one place up in the sequence.
Unless you have all of the files named similarly, I don't know what you can do.
So I really shouldn't have posted all of this useless information.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
Silver
  • Last login:April 16, 2025, 04:09:53 pm
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #5 on: January 30, 2006, 08:27:42 am »
Do you actually mean rename the roms files or the screenshot files? PResumably Mamewah is only showing you the rom names not the screenshot names?
Anyway, I thought mamewah could both strip clone, (), [], info from romnames, and also 'fuzzy' match screenshot names so you don't need to rename anything? Or am I wrong?
joe jet
  • Last login:June 01, 2008, 04:19:25 pm
  • Trumpy
« Reply #6 on: January 31, 2006, 08:41:56 am »
Isnt there something equivalent to Catver.ini that would translate the goodnames file name to the actual game name?
I have yet to move on to consoles on my cab, but this is something i have always wondered also....  i set up just like 10 snes roms and mamewah shows only the filenames (- the .zip)
