Author Topic: MTA Connector Wiring  (Read 1551 times)
Fusion Disaster
  • Last login:November 20, 2006, 01:00:26 pm
« on: January 23, 2006, 12:50:04 pm »
I ordered a full set of .156 & .100 MTA connectors so I can rewire my xenophobe cabinet. I got the connectors and sat down to wire it up last night, but realized I have no idea how to wire these connectors. They look pretty straight forward. Looks like there is no need to strip the wire, you just need to hold wire perpendicular to the connector and then shove it straight down into the bladed slot.
I tried shoving it down with my finger, a flat head screw driver, pliers, etc... No luck. Is there some trick to this, or a specialty tool or something?
Anyhelp is appreciated!
Fusion Disaster
Re: MTA Connector Wiring
« Reply #1 on: January 24, 2006, 11:40:32 am »
<Bump> Anyone know about these connectors?
BobA
  • What Me Worry?
« Reply #2 on: January 24, 2006, 11:21:12 pm »
Think you need a manual (single wire at a time) tool.  Probably around $20 from whoever you got your connectors from.
A pistol type tool costs $200 or more.
Link showing T handle tool in use.
http://www-ppd.fnal.gov/tshaw.myweb/CMS/HV/TERM_HV_Cable.pdf
I think there is a separate tool for  .100 and .156
« Last Edit: January 24, 2006, 11:26:57 pm by BobA »
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #3 on: January 25, 2006, 12:59:01 am »
Fine-tip needlenose pliers work, but it's a pain in the butt.
Fusion Disaster
« Reply #4 on: January 25, 2006, 11:11:41 am »
Thanks BobA for the pics, that helps alot! I'll give the pliers another try, otherwise I'll be ordering a tool.
B.
