Author Topic: Ipac and Optipac questions  (Read 1117 times)
mumbles
  • Last login:January 25, 2024, 09:20:01 pm
« on: January 23, 2006, 01:21:20 am »
Hi,
In my computers bios it has a setting where you can turn the computer on by pressing the right mouse button.  I have an optipac and a usb cable for it. If i connect a button to the right mouse button connection on the optipac will i be able to turn the computer on by pressing this button, just as if i had pressed the right mouse button??
Also i have a button on my arcade control panel for exit game. Now in some of my emulators you have to press the "esc" button to exit the game. Am I able to hook up my exit game button to the optipac and this will cuase it to use the "esc" button??
Thanks in advance
Tiger-Heli
    • Tiger-Heli
Re: Ipac and Optipac questions
« Reply #1 on: January 23, 2006, 06:27:59 am »
Hi,
Should be able to, never tried that for sure.
Thanks in advance
Not on the opti-pac (unless you can program the emulator to exit on mouse clicks, MAME will allow this), but you could with the I-PAC. . .
