Author Topic: WG25K7193 Monitor Board: Have it fixed locally or send it out?  (Read 1305 times)
Luckydevil
  • Last login:August 02, 2007, 01:38:45 pm
  • mmmm.... kilowatts.
    • Garage Junkies
« on: January 22, 2006, 08:10:25 pm »
A few of you guys have been helping me along with my monitor woes and I am extremely grateful. Unfortunately I think it is beyond my skills at this point.
The monitor has a brand new flyback and cap kit, unfortunately after I installed those I forgot to plug in the remote board and it killed something else. The monitor would power up, just nothing on the screen.
I assumed it was the HOT, so I replaced it and the other large transistor with replacements. Now the monitor won't even power up.  :(
I'm at a loss and to be honest I'm pretty fed up with this monitor and would much rather just have someone else fix it.
Should I risk the local TV repair guys to fix this monitor, or can I just send out the board to someone and have them fix it? How much $$$ am I looking at considering the board needs some troubleshooting?
Thanks guys.
*(Forgot to add that I have also resoldered most of the solder points on the board since that is recommended pretty often for troubleshooting.)
Ken Layton
  • Guru
  • Technician
Re: WG25K7193 Monitor Board: Have it fixed locally or send it out?
« Reply #1 on: January 22, 2006, 08:47:09 pm »
Hyperspacearcade.com will repair it for a lot less than a tv shop would charge. Suggest sending it there.
Luckydevil
    • Garage Junkies
« Reply #2 on: January 22, 2006, 09:36:05 pm »
That's exactly what I was looking for. Thanks a ton Ken!
