Author Topic: adjusting 4-way Wico leafs  (Read 1452 times)
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« on: January 20, 2006, 06:49:51 pm »
I just installed my 4-way Wicos and want to adjust the back leafs so they are nice and close to the contact leaf..
how do you guys do it?  Do you bend the whole leaf(s) from the base (so the whole leaf kinda slants at an angle toward the other leaf switch) or do you just bend the very top of the leaf where the contact point is?
NoOne=NBA=
Re: adjusting 4-way Wico leafs
« Reply #1 on: January 20, 2006, 07:40:57 pm »
I bend BOTH leaves at the base.
On the 4-ways, you have to be really careful not to get them too tight, or they quit being 4-ways and become 8-ways.
You want them set so that they contact as near as possible to center, but not so close that you can hit diagonals.
It takes a bit of round-and-round adjusting to get them just right, and you need to tweak them every now and then to keep them functioning at peak efficiency.
When they are perfect, you'll see the one leaf just break contact as the next makes contact--all the way around.
The 8-ways are easier in that you just need to find a good balance for how much of the perimeter travel needs to be a diagonal.
If you get them too tight, the diagonals will take up too much of the pie as you go around the outside.
Too loose, and they will take up too little.
Your goal should be to get eight equal sections as the stick goes around the perimeter of its travel.
There are games that you may want to tweak a stick for as well.
Crazy Climber is one of these.
It plays best with a stick that requires almost no travel Up/Down to contact, but considerable travel Left/Right.
That allows you to have more "on" time as you are climbing straight, but keeps you from accidentally hitting diagonals.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: January 20, 2006, 07:54:01 pm »
personally, i think the two leaves are close enough as it is when they are straight.
NO MORE!!
NoOne=NBA=
« Reply #3 on: January 21, 2006, 08:40:38 pm »
Perfect is right around straight out.
Most of the NOS ones I've picked up have the leaves bent out slightly when they come out of the box though.
I like to keep the stick as tight as possible though, so that it is more responsive in games where you need to switch repeatedly to opposite directions.
