Author Topic: Monitor Tilt Question  (Read 1670 times)
Teebor
  • Last login:June 04, 2009, 12:39:06 pm
  • What does this button do??
« on: January 18, 2006, 07:07:52 am »
Hi,
I have been reading alot and have got enough parts to start constructing my first scratch built cabinet shortly, the prototype panel is built/being modified already
BUT I have a question.  In my searches for parts I got some very good deals including a 33 inch monitor that cost about
How was your french toast dear?
Smelly and ungrateful
-American Dad
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
Re: Monitor Tilt Question
« Reply #1 on: January 18, 2006, 11:45:15 am »
Check out some real machine plans, and see what you think.
I like the pac/gal* leaned way back (30 degrees from horizontal, I think) monitor, especially if the tube on the monitor sticks way out the back.  You can get a smaller footprint cabinet that way.
Flinkly
  • Last login:July 30, 2026, 06:03:12 pm
« Reply #2 on: January 18, 2006, 11:55:01 am »
i think most scratch built cabinets have a 10 degree tilt backwards.  it makes for a better viewing of all different kinds of games.
Teebor
« Reply #3 on: January 18, 2006, 12:06:34 pm »
I will give 30 degress will give a smaller footprint?  I might have to give that a go.
I kind of like the 10 degrees tilt, anything other then upright has got to be good.
I was originally trying to make a machine that would look like Mortal Kombat II remake, but because of the sheer size of the screen now I don't think that possible at all.
-American Dad
Flinkly
« Reply #4 on: January 18, 2006, 12:17:47 pm »
just to point out the obvious, if you build a cab around this monitor, the cab won't be able to fit through regular sized doors...
Teebor
« Reply #5 on: January 19, 2006, 04:40:55 am »
:D
I am aware of that, The cabinet is going to be designed so that I can assemble it in the room it is going to be played in.
It is also going to be designed so that I can take it apart if I ever have to move it.  Although in reality it will probably only withstand about 2 or 3 rebuilds and then it may start to have problems.
Of course by then I plan to have moved on in the whole design stakes and will have built something else by then.
-American Dad
